H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..??
Old Jul 14, 2005 | 02:13 PM
Treblarefils's Avatar
Default H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..??
swapping in an h22 in a 97 hatch..Will the cables and assembly from a 91 accord work for this swap?..thanks
Old Jul 14, 2005 | 04:32 PM
BigBlockCRX's Avatar
New User
Default Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (Treblarefils)
yes
PM me if you have anyquestions, Ihave the same swap in my hatch
Old Jul 14, 2005 | 11:49 PM
Default Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (BigBlockCRX)
cool man..My friend has an old crappy accord that we are going to take the parts from but were curious as to if it would work for sure..less stuff to buy this way. Motor is already in..
Old Jul 15, 2005 | 03:59 AM
simon98h22's Avatar
Yup, you can use 90-93 accord shifter assembly and linkage for that swap.
Old Jul 15, 2005 | 05:10 AM
. o 69 o .'s Avatar
Default Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (simon98h22)
thats also what i used originally... eventually i switched over to a 94 prelude assembly when i could find one for cheap. It will sit about 1/2" lower and shift noticably faster, but the accord one definitely did the trick in the man time
VtecSickness
Jul 17, 2009 11:35 AM
HatchSpeeD
Oct 10, 2006 05:08 PM
SixguN
Nov 15, 2004 06:54 PM
its WANG yoO
Sep 24, 2002 02:15 PM
