Starter, Low Voltage?
Old Jul 14, 2005 | 12:26 PM
Rex_Ryder's Avatar
Default Starter, Low Voltage?
Starter showing low voltage (3-4 volts) and battery is fully charged and not loosing power. Any ideas of what the problem is?
Old Jul 14, 2005 | 12:27 PM
Rex_Ryder's Avatar
Default Re: Starter, Low Voltage? (Nu_At_It_CRX)
btw starter is in good condition.
Old Jul 14, 2005 | 03:29 PM
PrettyLude's Avatar
check the cables over again going to the starter
Old Jul 14, 2005 | 08:39 PM
Rex_Ryder's Avatar
Default Re: (PrettyLude)
GOT IT!!! It's been sitting for over a month and I finally got it pinned. A multi-meter sure is a life saver. I can't believe I didn't think to put the meter on the remote wire of the starter first. Anyways, the ignition switch was the culprit. I just pulled it out cleaned cleaned all the contacts with an emery board, greased the internal casing, and stretched out the springs. I am so pumped that it runs.
Thanks to all that contributed!!! H-T is the shizznit!!!
hondachris1994
12
Nov 9, 2017 05:15 PM
EGed up from the seat up
May 13, 2010 11:34 PM
Nisif
Nov 3, 2005 08:34 PM
HXvtec
Nov 6, 2004 02:15 PM
lsvtec101
Jul 21, 2004 05:12 AM
