What's the maximum shot of Direct Ported nitrous I can use on a stock H22A block?
I've heard people saying 75shot of nitrous direct ported is safe for occasional use.
True? Opinions please. Facts better! Thanks.
You can shoot a 100 shot once in a while, if you have a well tuned system and all of the goodies. Personally I won't go above a 75 shot.
For DP, isnt the minimum 80 shots? That what it says on the NOS web site. Could have changed I guess.
I probably wouldn't go past 75DP either. Is there anyone on this board that is using a 75DP on a H22A?????
thanks.
thanks.
i would not go past a 75 shot but most the people i know spayin is runnin a 55 shot and there car is cool and they spay all the time.
hmmmm, a 55shot will, on average, improve times up to a full second, i've heard.
I would like to try a 75shot if it's safe on the H22A motor.
Does anyone know anyone using this setup on a 5th gen lude???
Micrew: I'll be running a 75 shot on my 4G this spring. What do you need to know?
i have a 55 shot fomr a zex kit on my 95 jdm h22 accord. i run it every so often, and havent had any problems at all. i have all the goodies, I/H/E, clutch, flywheel,ignition, yada yada. i havent got a track time to tell you how much difference cause i snapped my axle in half at the tree. but ill have one soon. ive had it afor about 5 months now, and no problems yet
I'm running an 80 shot single fogger on my stock H22 block. If youre not planning on going above 75 there is really no need to go direct port.
