TWM ITBs sticking
My TWM ITBS are sticking at low RPMs, under 3500. They have the new style linkage on them and other than that are great. What can I do to get them to fully close. I searched for topics on here but didn't really find anything helpful. I have the dual return springs on them as well.
i have a set mine use to stick.............. make sure there clean at all times keep dirt and grease etc of them and this will help a lot i kno it helped out with the ones i have. adjust the idle screw or the hex rods make sure there clean..... i just read about someone making a spring that hooks up to the itbs and when u left of throttle it aparently closes them so u dont gotta worry about them sticking............ i will try to find the thread........... good luck
I got them used from TWM, they were calibrated before I got them, so I didn't want to mess with the hex screws/hiem joints. I'll look at the idle screw and other things, I may put another big spring on where the 2 return springs are already.
averyvm
May 8, 2008 09:54 PM
