(lsVTEC)no vtec what so ever
Old Jul 13, 2005 | 11:02 PM
spoon23_JDizM AkA SpOoN20's Avatar
Default (lsVTEC)no vtec what so ever
i'm running a b16a2 fully built portflow head with skunk stage 2's,stock ls bottom, all bolt ons,walbaro fuel pump,pressure reg and guage,etc...basically my vtec is not kicking in but the vtec code is not turning up on my check engine...also we have ran all checks as far as timing,fuel,air,compression check, and nothing has rang a bell...need some help fellas...
Old Jul 13, 2005 | 11:15 PM
WickedSol's Avatar
Default Re: (lsVTEC)no vtec what so ever (spoon20)
Hmm...could be a number of things...vtec solenoid ground, connections to ecu, oil pressure switch, bad ecu?
first check to see if vtec solenoid clicks on...
Old Jul 13, 2005 | 11:32 PM
greasemonkeys's Avatar
Default Re: (lsVTEC)no vtec what so ever (SpdImge415)
knock sensor?
Old Jul 14, 2005 | 01:16 AM
WickedSol's Avatar
Default Re: (lsVTEC)no vtec what so ever (prodigysir)
Ahh yes...Knock sensor...I hope you had tapped one in on your b18 block...
Old Aug 27, 2005 | 06:48 AM
Rod.'s Avatar
Default Re: (lsVTEC)no vtec what so ever (WickedSol)
check the screen in the vtec solenoid
Old Aug 27, 2005 | 06:58 AM
jdmcx's Avatar
i didn't have a knock sensor and mine worked do you have any other codes comming up
Old Aug 27, 2005 | 08:52 AM
Rod.'s Avatar
Default Re: (lsVTEC)no vtec what so ever (jdmcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx &raquo;</TD></TR><TR><TD CLASS="quote">i didn't have a knock sensor and mine worked </TD></TR></TABLE>
same here
Old Sep 14, 2005 | 10:09 AM
DC2 Mang's Avatar
my friend had the same problem, he didnt ground his Vtec soleniod, but when he did ground it to the thermostat housing Vtec hit everytime, and he had no knock sensor wired either and ran a mugen chipped p28 ecu
Laojoeturbo
34
Jun 24, 2009 08:47 AM
909dc2
Oct 17, 2008 03:32 AM
pr3crx
Feb 5, 2004 10:04 AM
oMek
Dec 12, 2003 10:07 AM
r7
12
Jun 13, 2002 10:21 AM
