F22 vs H22\3
Old Feb 16, 2002 | 01:49 PM
rota426's Avatar
Default F22 vs H22\3
Anyone know anywhere I can find ALL the differnces between the F22 and the H23? I can get a 4th gen s for really cheap, I'm just trying to figure out if its worth it...4995...in good condition w/ only 50k on the engine. Any input would help. TIA.
Old Feb 16, 2002 | 01:56 PM
kevie88's Avatar
Default Re: F22 vs H22\3 (styler7)
Factory service manual will tell you EVERY difference. as for an engine swap, that's what I'm doing right now, and it's not that hard at all. It's probably the easiest swaP you can do.
Old Feb 16, 2002 | 02:53 PM
NONKonformyst's Avatar
There are a few major differences between the F22 the H23 and the H22. First off, the F22 has a SOHC setup, where as both the H23 and H22 are DOHC. The H22 motor uses Honda's VTEC technology, while the other engines do not. There are some variations of the F22 and the H23 that do feature VTEC although their power outputs don't provide much more than their non-VTEC siblings. I believe these engines are found in the newer Accords. Power output from these engines are as follows; F22=135bhp, H23=160bhp and H22=195bhp. Compression ratios are different as well, but I can't think of the exact figures off the top of my head. From what I know the H23 adapts very well to turbocharging and the H22 adapts well to supercharging and all-motor build-ups. So, basically all three of these engines are different (more differences than I could list here) and if you need to know any more, do a search and I'm sure you'll find much more info. I hope that helps.
Old Feb 16, 2002 | 07:58 PM
rota426's Avatar
Default Re: F22 vs H22\3 (93redLUDE)
****, I didnt think it was that bad in the f22. I didnt know it was an SOHC. I think I'll just keep saving for an h23, the go turbo. I dont wanna deal with a swap and a turbo.
killerintegra07
Oct 8, 2007 12:24 AM
91accordSE9
May 17, 2005 12:14 PM
mp15_LUDE
Apr 15, 2005 10:47 PM
digital66
May 21, 2003 06:59 PM
ImPoRtz
Jun 23, 2002 05:18 AM
