Miata Wheels on a 91 Civic
Old Feb 16, 2002 | 01:11 PM
Todd00's Avatar
I said I don't want a title!
Default Miata Wheels on a 91 Civic
I found a set of 14x6 4x100 +45 offset Mazda wheels at a junkyard that weigh 9.5 lbs a piece and look good to boot (seven spoke aluminum, kind of like the ITR wheel).
So, what I need to do to make these fit my 91? I assume I'll need to have the center enlarged to fit in a Honda. Otherwise, they should be good to go, right?
Thanks.
[Modified by Todd00, 5:11 PM 2/16/2002]
Old Feb 16, 2002 | 02:48 PM
Giuseppe's Avatar
Default Re: Miata Wheels on a 91 Civic (Todd00)
Todd00
talk to eg6ajk i think there are some issues with those rims
they'll fit just something has to be done...
dont quote me on it, it has something to do with machining
something...ask him hell give u more info..
hth..
Old Feb 16, 2002 | 03:33 PM
eg6ajk's Avatar
there were two kinds of the 14x6" (that doesn't matter), either way one is 12-12.5lbs (90-3) and (94-7 style (HX look) was around 10.75-11.5lbs
two issues:
you can't use them with 10.3" brakes (GSR/EX/TEG), fits fine over 9.4" brakes
second you need to enlarge the inner hub area to 57-58mm (stock Mazda is around 53-4mm) which is too small...
otherwise a good choice, and since its .5" wider you can run 205/55R14 for extra grip
Old Feb 16, 2002 | 04:02 PM
MysteryWagon's Avatar
Default Re: Miata Wheels on a 91 Civic (eg6ajk)
THey do fit, I put my friends miata wheels on my 90 hatch. THey do look good. the ones on the bottom are the ones I tried on my car.
Old Feb 16, 2002 | 04:21 PM
McD's Avatar
McD
Default Re: Miata Wheels on a 91 Civic (ShaggenWaggon)
I like the ones on the top... Gonna have to search for a pair now
Old Feb 16, 2002 | 06:34 PM
kefka's Avatar
Default Re: Miata Wheels on a 91 Civic (DX_Hatch)
ehh there light but i like the style of the civic hx rim better just go with those..
Old Feb 16, 2002 | 08:10 PM
SiR Kid's Avatar
New User
Default Re: Miata Wheels on a 91 Civic (madeinjapan)
The upper ones look like a 7 spoke Mini RX-7 wheel I likee
[Modified by SiR Kid, 11:10 PM 2/16/2002]
Old Feb 16, 2002 | 10:34 PM
Giuseppe's Avatar
speak of the devil u posted right after me...!
hows that for info at the touch of a button...!
good stuff.!
Old Feb 17, 2002 | 12:32 PM
Todd00's Avatar
Those are the ones that I picked up. I put them on another scale and they came to 10.5lbs, which is still incredibily light for a 14x6 wheel. And yea, I do like the extra .5"-1" extra width over the Honda wheels.
I have a guy that can bore out the hubs, so all is good. Going to paint them gunmetal and put a 'H' centercap on them, so they should look good.
Old Feb 17, 2002 | 12:43 PM
TypeR0207's Avatar
I sold my '94 Miata to my Dad when I bought the Type R, and I am seriously thinking about asking him for the old wheels since I had put 16's on the Miata .... (he doesn't need them!!).
Old Feb 18, 2002 | 04:55 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Miata Wheels on a 91 Civic (TypeR0207)
dude put the crack pipe down!!!!!!
If the rims won't clear stock 10.3" brakes, how they gonna fit over ITR sized. 11.1" brakes???
Old Feb 18, 2002 | 05:09 AM
TypeR0207's Avatar
Default Re: Miata Wheels on a 91 Civic (Mista Bone)
Duh .....
See Signature ......
Old Feb 18, 2002 | 05:37 AM
SiR Kid's Avatar
New User
Plus he just said that the wheels on the miata were 16"'s....
et with the program!
Old Feb 18, 2002 | 05:39 AM
TypeR0207's Avatar
Default Re: Miata Wheels on a 91 Civic (SiR Kid)
No .... I put 16" wheels on my old Miata, so the stock 14" are just sitting in my parents basement, waiting for me to scarf them up!!!
Plus older Miata are 4 bolt .... Type R's are 5 bolt ...... so they wouldn't work even if they were 16's on a Type R ......
And I had Enkei 17's on my Type R ....
GatorMark
May 5, 2005 08:46 AM
JapanExpress
Jan 5, 2005 08:28 PM
TylerC
Jan 12, 2004 09:00 PM
garados
Apr 1, 2003 07:39 AM
flat-blk-HB
Nov 25, 2002 05:53 PM
