Teg rear brakes help
Old Jul 13, 2005 | 06:31 PM
sureshot007's Avatar
Default Teg rear brakes help
I am trying to finish the rear disc swap on my civic, but I am having trouble with the calipers. I can't get the piston to compress enough to fit it over the new pads/rotor. Is there a trick to it that I am missing? I am using a large c clamp - its what I always use for this. The calipers are not on the car. Any suggestions?
Old Jul 14, 2005 | 04:41 AM
JimBlake's Avatar
Default Re: Teg rear brakes help (sureshot007)
Rear calipers have the handbrake ratcheting mechanism inside. You have to twist the pistons, don't just push them straight in. If you've already cranked on the C-clamp, maybe that stuff is already damaged??
Old Jul 18, 2005 | 03:46 PM
95greenteg's Avatar
Default Re: Teg rear brakes help (JimBlake)
yeah man...you have to twist the pistons clockwise in order for it to decompress...
mynameisChris
Aug 15, 2009 06:57 AM
loonysalmon
May 5, 2009 04:22 PM
pli
Aug 29, 2006 09:08 AM
ultrablackhatch
Jul 30, 2006 09:33 PM
twotone
Oct 11, 2002 05:11 PM
