ECU code 43 - 92 accord ex - some help please before I throw money at dealer
Old Jul 13, 2005 | 05:35 PM
oldfart's Avatar
Default ECU code 43 - 92 accord ex - some help please before I throw money at dealer
I am in need of some help - ECU code of 43 - fuel system - - most of the time the car runs fine - then normally in low rev times like just starting out it acts like it is out of time or no fuel - hit the gas and its fine -
Have checked the fuel pump it runs at key turn on and after starting it continues to run - pressure is released when you open gas tank so i am assuming the pump is working fine.
Any ideas on what to check next and is this code jsut a fuel system code - again 92 accord EX
Tomorrow I am checking Fuel pressure - and car has 230K on it
Old Jul 14, 2005 | 08:20 PM
oldfart's Avatar
Default Re: ECU code 43 - 92 accord ex - some help please before I throw money at dealer (oldfart)
Update - Checked fuel pressure - #1- turn key to on but no start -40lb #2 start/running 30 lb #3 with out vac connect and running - 40lb
What do you think - fuel pressure regulator? this is low limits on all readings
Help please?
Jahmani
Nov 9, 2018 03:53 PM
RacerRex
Apr 16, 2009 08:59 AM
-.1234P312.-^EK_SI^
Sep 8, 2008 07:24 PM
h22HatchEG
Jul 15, 2006 05:52 PM
