CRV motor in EK hatch.....
Hey. I usually hang out in the EF forum, but I want to get some opinions on my setup Im going to do on my EK hatch. I have a B20Z bottom end, B18B head (non-vtec), B16A 1st gen intake manifold, 4-2-1 header, and LS tranny. I havnt put it all together yet, I will this fall. I was wondering if anyone else has done this and what they think of it? I have the means to tune the ecu for these parts. What is the stock CRV horsepower? Cant wait to get-r-done (get-r-done is beginning to wear on me)
B20Z
Displacement (cc): 1973
Power (bhp@rpm): 146@6400
Torque (ft/lbs@rpm): 133@4500
Compression Ratio: 9.6:1
Bore (mm): 84
Stroke (mm): 89
Cam Design: dohc
VTEC?: no
OBD: 2
Year(s) Produced: 1998-2001
In the following car(s): Honda CRV
Bore (mm): 84
Stroke (mm): 89
Cam Design: dohc
VTEC?: no
OBD: 2
i think you should get a pr3 head(b16) and a shorter geared tranny like a gsr and you can make some nice n/a power or boost it for even more power...and you would might want to get a better IM
the B16 IM wont bolt up to the B18B head. you can get a Skunk2 Manifold for a LS which would put out a decent gain. I got a great gain from putting a Skunk2 Manifold and BBK 70mm throttle body on my B20B in my CRV. That should be a fun set-up for a EK but you wont pass inspection with a B20 because its considered a light truck motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YAMAHAtrueracer »</TD></TR><TR><TD CLASS="quote">the B16 IM wont bolt up to the B18B head. you can get a Skunk2 Manifold for a LS which would put out a decent gain. I got a great gain from putting a Skunk2 Manifold and BBK 70mm throttle body on my B20B in my CRV. That should be a fun set-up for a EK but you wont pass inspection with a B20 because its considered a light truck motor.</TD></TR></TABLE>
^^^^ true
by the way.. GSR tranny is wonderful for this... otherwise.. LS tranny is good.. longer gears.. highway terror!!
^^^^ true
the crv motor has about 135 ish and about 128 tourque im not to sure about this whole b16 manifold on the ls head if i were u i would put a b16 head or a b18c head on it and then u would have about 200hp i know people who have done the crv-vtec motor swap and it is very fast and pulls hard
You can get a Blox{LS} manifold off of Ebay for about $175, witch should be real close to a Skunk2 piece! That would be the way i would go....and i notice you guys keep saying stuff about a Crv motor won't pass smog because it is a light truck motor....WTH is that all about, they check your engine code when you go get a tag or something!?
I dont have emissions check in my county, so Im not worried. I dont think we ever will because some counties in Ohio here are looking at getting rid of them all-together I heard.
thanks, I didnt know the B16 IM wouldnt fit on the LS head (didnt check it myself). So I will either have to get a skunk or an LS IM, which I have. The B16 IM looks so much better!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by becoming »</TD></TR><TR><TD CLASS="quote">You can get a Blox{LS} manifold off of Ebay for about $175, witch should be real close to a Skunk2 piece! That would be the way i would go....and i notice you guys keep saying stuff about a Crv motor won't pass smog because it is a light truck motor....WTH is that all about, they check your engine code when you go get a tag or something!? </TD></TR></TABLE>
The blox manifold will work great and save you some $$$ where it counts. I work at a Honda Service Center and if the motor is swapped it must be the same OBD series or better to pass emissions/inspection and the motor must be of the same class (car-car motor) The B20B is registered as a "light truck" motor because it comes in a CRV so a light truck motor in a car is a no-no to them. BUT DO IT ANYWAYS especially since you already have the parts. Just get it inspected/emissions right before you swap it out
