H23 crank in H22 block?
Old Jul 13, 2005 | 02:57 PM
hu's Avatar
hu
Default H23 crank in H22 block?
I want to stroke my H22, but do not want to spend 4000 on a kit from Crower. Can I use a H23 crank in the H22 block? I will sleeve the block and do an offset ground on the crank.
Old Jul 15, 2005 | 05:11 PM
hu's Avatar
hu
Default Re: H23 crank in H22 block? (hu)
anybody know?
Old Jul 15, 2005 | 09:14 PM
RMS's Avatar
RMS
what stroke do you want? the h23 or f22 cranks are already 95mm.
Old Jul 16, 2005 | 03:55 AM
hu's Avatar
hu
Sleeved block with a 89mm bore
H23 crank offset ground to 1.771 (98mm)
custom rods and pistons
this should put me at 2.4L
Old Jul 16, 2005 | 07:40 AM
RMS's Avatar
RMS
personally, i considered going with an offset grind on my build but couldn't justify the extra $/effort/replacement for only .1 liter of additional displacement over the f22 crank. bob at ari in fl has done alot of those though.
Old Jul 16, 2005 | 07:26 PM
hu's Avatar
hu
It should be .2 because I am using the H22 block and inserting a reworked H23 crank.
Old Jul 16, 2005 | 08:45 PM
The_Head's Avatar
https://honda-tech.com/zerothread?id=1245350
Just offset grind your H22 crank
Old Jul 16, 2005 | 10:44 PM
hu's Avatar
hu
I thought of that, but it doesnt look like I can get 98mm.
H22 crank:
84.7 (1.654 journal diameter - destroke) 1.772 BE bore (rod)
87.7 (1.771 journal diameter - destroke) 1.890 BE bore (rod)
90.7 (1.888 journal diameter - stock stroke) 2.008 BE bore (rod)
93.7 (1.771 journal diameter - stroke) 1.890 BE bore (rod)
96.7 (1.654 journal diameter - stroke) 1.772 BE bore (rod)
H23/F22 crank:
89 (1.654 journal diameter - destroke) 1.772 BE bore (rod)
92 (1.771 journal diameter - destroke) 1.890 BE bore (rod)
95 (1.888 journal diameter - stock stroke) 2.008 BE bore (rod)
98 (1.771 journal diameter - stroke) 1.890 BE bore (rod)101 (1.654 journal diameter - stroke) 1.772 BE bore (rod)
It looks like I have to use a H23 crank. Correct me if I am wrong...please.
lowacc97
Jan 9, 2012 02:47 PM
gc8dc95
Dec 30, 2010 07:02 AM
jdm.fanatic
Apr 24, 2010 04:29 PM
kwik93si
Jul 26, 2003 04:20 PM
civicsitek GanGsTa
May 20, 2003 04:16 PM
