converting to obd-1 which harness do i use?
Old Jul 13, 2005 | 09:42 AM
hatchinprogress's Avatar
Default converting to obd-1 which harness do i use?
i have a '90 crx(wired up as an si) and im going to install a d16z6(obd-1)....well i have the complete engine harness that came with the z6, and i have a si harness.(my friend already made the ecu conversion harness) but for the engine which harness do i need to use???? (i think i need to use the z6 harness, it has the matching clips already...but my friend says to use the si harness and make that work)
Old Jul 13, 2005 | 09:45 AM
EP3_05's Avatar
Default Re: converting to obd-1 which harness do i use? (hatchinprogress)
The OBD1 engine harness will not plug into the interior harness so you need to use the stock Si harness and mod it to work on the d16z6 engine.
Old Jul 13, 2005 | 09:47 AM
turboLSef's Avatar
use the SI harness...
Old Jul 13, 2005 | 10:20 AM
Mach69's Avatar
Si harness. If you are going to use the obd-1 injectors, just take the injector clips from the obd-1 harness and put them on the obd-0 si harness. You will notice alot of the obd-1 and obd-0 engine clips are identical and in the exact same spots.
Old Jul 13, 2005 | 11:24 AM
Default Re: converting to obd-1 which harness do i use? (Mach69)
thanks guys that answered my question(i guess i was wrong..and my friend was right)
Old Jul 13, 2005 | 11:36 AM
4drEF's Avatar
Keyboard Humorist
Don't forget to delete the injector resistor box if you intend to use the OBD-1 injectors.
Old Jul 13, 2005 | 12:22 PM
Default Re: converting to obd-1 which harness do i use? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to delete the injector resistor box if you intend to use the OBD-1 injectors.</TD></TR></TABLE> how do i delete the resistor box? or should i run obd-0 injectors??
Old Jul 13, 2005 | 01:16 PM
turboLSef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> how do i delete the resistor box? or should i run obd-0 injectors??</TD></TR></TABLE>
you dont need to switch the injectors... just leave them obd0 unless you want to... then you'd remove the resistor box and switch the injectors and clips
Old Jul 13, 2005 | 02:59 PM
Default Re: converting to obd-1 which harness do i use? (turboLSef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboLSef &raquo;</TD></TR><TR><TD CLASS="quote">
you dont need to switch the injectors... just leave them obd0 unless you want to... then you'd remove the resistor box and switch the injectors and clips </TD></TR></TABLE>ok let me make sure i get this right......if i keep the resistor box(even though i will be obd-1, i need to use obd-0 injectors(correct?) and the only reason i would have to use the obd-1 injectors is if i remove the resistor box????
Old Jul 13, 2005 | 03:18 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">ok let me make sure i get this right......if i keep the resistor box(even though i will be obd-1, i need to use obd-0 injectors(correct?) and the only reason i would have to use the obd-1 injectors is if i remove the resistor box????</TD></TR></TABLE>
Correct. OBD-0 injectors = low impedance and require a resistor box to raise the impedance of the circuit so as not to overload the injector drivers in the ECU.
OBD-1 injectors = high impedance injectors. The resistor box is not needed, as the impedance of the circuit is already high enough. Running a resistor box would raise the impedance of the injector circuit higher that it needs to be.
Old Jul 13, 2005 | 04:05 PM
Default Re: converting to obd-1 which harness do i use? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
OBD-1 injectors = high impedance injectors. The resistor box is not needed, as the impedance of the circuit is already high enough. Running a resistor box would raise the impedance of the injector circuit higher that it needs to be.</TD></TR></TABLE> thanks and turboLSef
JJGL-EF90
Nov 26, 2010 10:30 PM
accord2civic2prelude
Aug 14, 2009 05:42 AM
purple98ek
30
Nov 8, 2007 08:53 AM
KevronsEG
11
Jun 28, 2002 09:23 AM
