"Tiny bubbles"........and its not the song!
Old Jul 13, 2005 | 08:01 AM
Palmertime's Avatar
Default "Tiny bubbles"........and its not the song!
My cuz is having issues! Radiator fluid is being pushed into and out of his radiator overflow and there are tiny bubbles in the mix as well. This being nothing but bad news we cracked the head and found some interesting results. First off here are the specs of the motor: B18C1 (GSR) bored and sleeved by golden eagle to 85mm, 12:1 compression, portflow head with all the goodies, stock honda OEM head gasket laser cut to fit the bore, stock head bolts and the motor has 4K miles on it
After cracking the head we found out there was no dropped sleeve or cracked head gasket, thats a relief...... i think. But we noticed that there was a lot of wear on the head gasket between each cylinder but no visible cracks. Cylinder 1, i think..... the passanger side cylinder closest to the distributor had a tiny bit of rust on the wall but all other cylinder walls are ok and spotless.
Our conclusion is the head might not have been torqued down enough or that it was torqued down wrong. A new head gasket along with ARP studs and more torque is what we are thinking to solve this issue.
Any thoughts on what the problem could be? A solution or any ideas would be apriciatted!!!!!
Peace Out,
Palmertime
Old Jul 13, 2005 | 08:14 AM
msmotorsports's Avatar
Default Re: "Tiny bubbles"........and its not the song! (Palmertime)
Do not overtorque the head studs past the recomended specs that ARP gives you. Be sure to use the ARP assembly lube so you get consistent torque. If you are confident the head is torqued properly and to spec and your problem has not gone away, then the problem lies elsewhere.
Old Jul 13, 2005 | 08:42 AM
Palmertime's Avatar
Nice...... Thanks for the tip
Old Jul 15, 2005 | 09:35 AM
Palmertime's Avatar
Has anyone had this happen before? if so what was the solution?
Thanks,
Palmertime
Old Jul 15, 2005 | 11:00 PM
Toxidomask's Avatar
they recomended torquing 70lbs, but my gasket still leaked. then I retightened it 75lbs, oil like is now dimminished to gone. it sux that at times you have to retorque ARP....... next time try AEBS. I regret buying ARP, even though everyone is for it.. I was thinking AEBS is better designed; and does not require torquing after 1000 miles or so.
andrew714
Feb 18, 2016 05:20 PM
mustangsvo85
Sep 23, 2009 04:48 PM
Br1t1shguy
Dec 16, 2006 07:27 PM
bdicustoms
Aug 25, 2004 07:35 PM
b18cx
Jun 10, 2004 03:31 PM
