Lubing Stock Shifter in '99 EX Sedan??
Old Jul 13, 2005 | 06:19 AM
shortlid's Avatar
Default Lubing Stock Shifter in '99 EX Sedan??
Ok, I jacked up and put my girls '98 EX sedan with 74k on jack stands. I crawled under there and lubed ALL the shift linkages between the shifter bottom and the tranny. Was a fair abount of rust on the vibration damping "thingy" behind the shifter under the car. I guess the exhaust heat gets to it ? The I unscrewed the arm rest and center console. Pulled it out cleaned all the old grease out and used multi-purpose grease on the ball part of the shifter bottom inside the car. I could not get to the bottom part of the ball on the shifter cause there was this tight fitting rubber boot in the way under the car?? Well it loosened up for awhile, then when the car warmed up it got EVEN stiffer between third and fourth??? Seems like the shifter is smooth when you first drive in the morning but as the exhaust heats the shifter bottom up it starts to get stiff???? Anyone had this his happen with the stock shifter???
JDM_rolex
Jan 1, 2014 07:16 PM
Boostn B20
Jul 12, 2011 07:35 PM
mistersparco
Jan 19, 2007 11:20 AM
LaloQuera
Oct 3, 2006 12:34 PM
slash00R
Nov 1, 2004 07:23 PM
