Underdrive Pulleys
Old Jul 12, 2005 | 08:25 PM
drifter_for_life06's Avatar
Default Underdrive Pulleys
What do you guys think about: AEM Tru Power Underdrive Pulley Kits
found em for 145 before shipping, and thinkgin about ordering them tomorrow morning
any opinions?
Old Jul 13, 2005 | 06:49 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Underdrive Pulleys (drifter_for_life06)
Old Jul 13, 2005 | 08:59 AM
AFAccord's Avatar
Default Re: Underdrive Pulleys (Vt4cPwn35)
I just installed them on my 99 Accord 4cyl yesterday. There was a definate improvement, but it's difficult to describe. Car didn't feel more powerful (since it literally isnt), but it seemed much less sluggish off the line and the acceleration was more fluid after changing gears. According to a G-Tech Pro meter, it smoothed out my torque curve, which is exactly how it felt. The pulleys did exactly what I thought they would do, and I am very happy with the purchase. If you can get ahold of one, an impact wrench makes this a quick install, not having to remove the alt, or ps pump. Just loosen the belt tension, and pop the pulleys off. Hope this helps!
Old Jul 13, 2005 | 10:44 AM
Thanks!
Were tehy easy to install, or would they be w/o the impact wrench
Old Jul 13, 2005 | 12:51 PM
AFAccord's Avatar
Default Re: (drifter_for_life06)
I tried the day before using my own tools. Even though I had the correct size wrenches and sockets, I couldn't manage to do it. I was nearly impossible to get enough torque to break the nuts free while holding the pulley's still. 1.5 hours with traditional tools = didn't budge. 10 min with impact wrench = popped right off.
Old Jul 13, 2005 | 01:36 PM
accordselux's Avatar
Me Gusta History
Default Re: (AFAccord)
I had some but I sold them on ebay for 130.00 because it was too much effort. You should have asked earlier when I was selling them!
Old Jul 13, 2005 | 02:03 PM
Damn, I hope I can do it with the regular tools.
Where can I pick-up an impact wrench?
Old Jul 13, 2005 | 02:13 PM
AFAccord's Avatar
Well, I don't know where'd you be able to "pick one up" without picking up a compressor and air hose too. I did mine at an auto hobby shop on base. I'm sure with some liquid wrench, you could manage it. Otherwise, you might see if any car service center would be kind enough to pop them loose, then maybe roll it out of their bay for you to finish. Just remember to check this... my 6th gen PS pump nut came off normal, but i hear some other gen accords might be reverse threaded. Good luck!
Old Jul 13, 2005 | 03:49 PM
i got some PB BLaster, that might work
anyone with a 5gen knwo if they come off reverse or normal?
Old Jul 13, 2005 | 04:16 PM
momstaxi's Avatar
yes, the fifth gen power steering pumps have a reverse threaded shaft/nut. the alternator, however, is standard threads...
Old Jul 13, 2005 | 04:31 PM
goowakjai
Guest
Posts: n/a
Default Re: (momstaxi)
remember when ur installing to torque it down to its spec...dats the cause of alota people bitching about aftermarket cams slipping...and if u have toe money tune it on a dyno, thats the only way to get the most HP
Old Jul 13, 2005 | 04:41 PM
AFAccord's Avatar
Default Re: (goowakjai)
I think you could skip the dyno if you're just adding pulleys. Nothing to tune really.
Old Jul 13, 2005 | 05:11 PM
NAiL05's Avatar
I got a UD pulley for my accord. No power gains but it does rev a bit easier.
Old Jul 13, 2005 | 06:09 PM
should i torque them to factory specs?
what si the factory spec?
Old Jul 13, 2005 | 06:20 PM
NAiL05's Avatar
I dunno what the spec is but i just impact them back on lol but im sure thats prob bad but it works.
Old Jul 13, 2005 | 06:47 PM
AFAccord's Avatar
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno what the spec is but i just impact them back on lol but im sure thats prob bad but it works.</TD></TR></TABLE>
My thoughts exactly...
Old Jul 13, 2005 | 07:43 PM
shrekz's Avatar
it would be hard tightening the bolts back to spec anyway, i just use an old timing belt have one guy hold the timing belt while someone else torques the nut...strap wrench? save your 20dollars use the old timing belt
Old Jul 13, 2005 | 07:47 PM
AFAccord's Avatar
Default Re: (shrekz)
good idea! but these two belts are serpentine, and don't have notches perpendicular with the belt, so they don't exactly "hold" to the pulley.
Old Jul 13, 2005 | 08:19 PM
i donno im lost
then again im SUI (surfing under the influence)
Old Jul 14, 2005 | 02:35 PM
goowakjai
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">remember when ur installing to torque it down to its spec...dats the cause of alota people bitching about aftermarket cams slipping...and if u have toe money tune it on a dyno, thats the only way to get the most HP</TD></TR></TABLE>
haha, my bad, u guys talking bout underdrive pulleys, i was thinking cam gears
Old Jul 14, 2005 | 03:50 PM
ahh gotcha
Old Jul 15, 2005 | 09:33 PM
alright one last question, think ill be able to do this with basic tools/wrenches?
Im gonna check back and have another look formyself and probably order them in the AM if the repsonses are positive
aznteg
Jun 7, 2005 01:26 PM
xplanetearth420x
Apr 16, 2004 10:53 AM
truthaccord
Apr 6, 2004 08:35 AM
integraautox
Jul 25, 2002 06:47 AM
smokin rubber
Oct 26, 2001 08:06 PM
