JDM GSR Dyno
Old Jul 12, 2005 | 07:05 PM
Easyslider01's Avatar
Default JDM GSR Dyno
I had my car dyno tuned today at Tempest Racing in Waldorf, MD. I'm sorta disapointed in the numbers put down, was hoping for 190whp but feels much faster.
<U>MODS</U>
JDM GSR
Hondata S100 Tuned P28
Skunk2 Intake Mani
Buddy Club Spec 3+ Cams (with titanium springs, retainers, and cam gears)
DC Sports JDM Header
APR Head studs and all new gaskets
Ebay short ram
Warlbro Fuel Pump
42psi on B&M FPR
310 injectors
NGK plugs and wires
Clutctmasters stage 1
Old Jul 12, 2005 | 07:15 PM
sa90eg's Avatar
Default Re: JDM GSR Dyno (Easyslider01)
good numbers.....
Old Jul 12, 2005 | 07:21 PM
djmatix's Avatar
whoa, your horsepower falls off at 6.5k????
Old Jul 12, 2005 | 07:32 PM
8krdline's Avatar
Default Re: (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">whoa, your horsepower falls off at 6.5k???? </TD></TR></TABLE>
thats what I'm saying. If they tuned it, I'd take it back bc your graph should not look like that at all
Old Jul 12, 2005 | 07:53 PM
Default Re: (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">
thats what I'm saying. If they tuned it, I'd take it back bc your graph should not look like that at all</TD></TR></TABLE>
I don't know, they said it was best they could get it. The cams are real mid-range cams so i'm guessing why.
Old Jul 12, 2005 | 09:10 PM
asefi944's Avatar
Default Re: JDM GSR Dyno (sa90eg)
your manifold is the problem bout the power dropping i had the same problem.
go with jg edlebrock. i made 200@whp.....gsr with skunk stage 1 cams...intake etc.
Old Jul 12, 2005 | 10:01 PM
Motorhead_AZ's Avatar
Default Re: JDM GSR Dyno (asefi944)
Why do torque and HP lines cross at 7350?
Old Jul 13, 2005 | 01:23 AM
WickedSol's Avatar
Default Re: JDM GSR Dyno (Jimmy)
Its because the TQ values on the graph is shown by 5 ft. lbs, whereas the WHP values are shown by every 10... most dyno graph have the same values on both sides...
BTW: Decent #'s considering stock bottom end...
Old Jul 13, 2005 | 03:21 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">whoa, your torque falls off at 6.5k???? </TD></TR></TABLE>
Fixed it for you.
The torque decline isn't that bad. Look at the scale on the right. The redline torque is 88% of the peak torque.
Old Jul 13, 2005 | 07:19 PM
Default Re: (Dogginator)
the redline is 9k, should i rev it out?
Old Jul 13, 2005 | 11:03 PM
WickedSol's Avatar
Default Re: (Easyslider01)
There is no need to, your peak hp drops of at 8400...you can achieve higher peak power with a better header, test pipe, 2.5" exhaust...
Old Jul 14, 2005 | 04:55 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Easyslider01 &raquo;</TD></TR><TR><TD CLASS="quote">the redline is 9k, should i rev it out?</TD></TR></TABLE>
Why did you quit at 8400 RPM? I assume that your setup had adequate fuel for 9000 RPM.
I think that you found the HP peak, but you could extend the range a bit to keep the HP up after shifting.
rollmydice
Oct 6, 2005 11:54 PM
Easyslider01
11
Sep 15, 2005 06:48 PM
Easyslider01
17
Jul 12, 2005 09:19 PM
myhatchrips
Feb 9, 2004 07:18 PM
MUGEN_B16CIVIC
30
Jan 13, 2004 04:02 PM
