Anyone w/ a reprogrammed ECU?
Old Feb 15, 2002 | 11:46 PM
akkording's Avatar
New User
Default Anyone w/ a reprogrammed ECU?
Thinking about getting my ECU worked on. I know Hondata is the **** but I want to know about the others. What did yall have modifided on the ECU and what program ex. mugen, spoon, dinan, custom. Thanks
Old Feb 16, 2002 | 09:13 AM
JG Luder's Avatar
Default Re: Anyone w/ a reprogrammed ECU? (akkording)
I ran a spoon program for about 3/4 of a mile.
Brian (SN is Prospeed) did it for me.
Old Feb 16, 2002 | 10:31 AM
prospeed's Avatar
Default Re: Anyone w/ a reprogrammed ECU? (JG Luder)
I also have my own custom program for the H22a upgraded fuel and timing for guys with bigger cams and higher compresson. 9000prm rev-limit! I wish JG that you could have enjoyed that ecu for longer! Its alrite though you working on the Turbo motor?
Old Feb 16, 2002 | 01:10 PM
akkording's Avatar
New User
Default Re: Anyone w/ a reprogrammed ECU? (prospeed)
Hey Brian do you know Roland from Ung Motorsports in Houston?
Old Feb 16, 2002 | 02:05 PM
JG Luder's Avatar
I will be enjoying it soon enough.
Old Feb 16, 2002 | 04:29 PM
prospeed's Avatar
Yes i do know roland. I will be supplying reprogrammed ecus for them!
Old Feb 16, 2002 | 04:57 PM
migo's Avatar
New User
ProSPeed, so how much would you charge for a re-programmed ecu. email me
Old Feb 16, 2002 | 05:11 PM
prospeed's Avatar
Default Re: Anyone w/ a reprogrammed ECU? (D.specs)
You have mail!
Old Feb 17, 2002 | 01:54 AM
akkording's Avatar
New User
Any info on what a Mugen program consist of?
Old Feb 17, 2002 | 03:41 AM
Islander9407's Avatar
New User
Prospeed: I own the Hondata Stage 4 system. I was wondering if you would send me your custom program for the H22A. Also, what size/brand cams is the tune done for? What compression? In my country I'm the only guy with the Hondata system so I'm trying to gather as much maps as I can so that I could offer the service here.(we don't have any dynos) My car is a turbo 1993 Honda Prelude Vtec(black) and you could view some old pics at http://www.islandguyz.com . Hope you reply soon.
[Modified by Islander9407, 12:42 PM 2/17/2002]
[Modified by Islander9407, 12:43 PM 2/17/2002]
Old Feb 17, 2002 | 12:10 PM
prospeed's Avatar
Were u interested in the mugen program for the p28 of p13?
Old Feb 17, 2002 | 12:15 PM
prospeed's Avatar
Default Re: Anyone w/ a reprogrammed ECU? (Islander9407)
Sorry the programs that i do have will not be compatible with the Hondata setup. I am a Hondata dealer and i know that they run a different language then the programming i do for the h22a. I recommend you getting the motec wideband o2 sensor if you do not have a dyno. It would allow you to drive it down the street and monitor the air/fuel ratio! Tune around that and you should be fine!
Old Feb 17, 2002 | 06:53 PM
akkording's Avatar
New User
I sent you an E-mail Brian. Thanks
B16beatdown
14
May 6, 2004 05:10 PM
lke2drvgsr
Feb 16, 2004 06:13 AM
mattmw88
Feb 1, 2002 01:58 AM
