NEED PIN OUTS!!!
Old Jul 12, 2005 | 03:37 PM
90 Si Hatch's Avatar
Default NEED PIN OUTS!!!
Hey whats up every one, I am needing the Pin-Outs on a PWO or PR3 ECU if some one could help me out. I have already searched. Thanks
Isaac-
Old Jul 12, 2005 | 04:28 PM
NikoZai's Avatar
Default Re: NEED PIN OUTS!!! (90 Si Hatch)
http://effinmotorworks.com/Effin_MPFI_swap.htm
That's it. just doesn't list the VTEC wiring
A8 = VTEC Solenoid
B5 = VTEC Oil pressure
B19 = Knock Sensor
C8 = Secondary O2 Sensor. (or swap that with C16)
Old Jul 13, 2005 | 09:08 AM
bump
Old Jul 13, 2005 | 01:55 PM
Default Re: NEED PIN OUTS!!! (NikoZai)
bump!!!!
Old Jul 13, 2005 | 11:34 PM
HxCforever's Avatar
are you looking to buy ecu pins?
Old Jul 13, 2005 | 11:59 PM
Malgerus's Avatar
Default Re: NEED PIN OUTS!!! (notoriousED7)
Here are the PW0/PR3 pinouts (another site): http://www.hondata.com/techwiringpw0.html
Old Jul 25, 2005 | 05:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousED7 &raquo;</TD></TR><TR><TD CLASS="quote">are you looking to buy ecu pins?
yeah those too????
Old Jul 25, 2005 | 05:17 PM
dr_latino999's Avatar
All the pinouts you can need for a while, lol - check my thread - https://honda-tech.com/zerothread?id=1319235
Old Jul 26, 2005 | 10:45 AM
Default Re: NEED PIN OUTS!!! (dr_latino999)
no, now i need the pins that go in the molded plug
Old Jul 26, 2005 | 11:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 Si Hatch &raquo;</TD></TR><TR><TD CLASS="quote">no, now i need the pins that go in the molded plug</TD></TR></TABLE> Being...which plug?
Old Jul 26, 2005 | 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Being...which plug?</TD></TR></TABLE>
Ok, now here is what I have. I am using a 97 SOHC V-tec (D16Y8), and i am staying OBD-0, and i am going to run an OBD-0 ECU PR3 or PWO, and i have to run 2 wires to the ECU "A8" & "B5" and i need the Pins that go in the plugs.
So Where to find them?
Old Jul 26, 2005 | 01:42 PM
I believe you can steal some pins from wires labeled AUTOMATIC only on OBD-0 harnesses.
Old Jul 27, 2005 | 06:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">I believe you can steal some pins from wires labeled AUTOMATIC only on OBD-0 harnesses.</TD></TR></TABLE>
What do you mean by that?
Old Jul 27, 2005 | 09:12 AM
If you look at your wire harness, there are unused pins/wires from spaces that say on wire diagrams AUTOMATIC only, or HF only; if not go to a junkyard and slash the end of an OBD-0 harness.
Old Jul 27, 2005 | 10:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">go to a junkyard and slash the end of an OBD-0 harness.</TD></TR></TABLE>
great didn't even think of that
Old Jul 27, 2005 | 11:43 AM
brokenojoke's Avatar
If you have no luck at your local yard, IM me and I'll send you one. Just pay me shipping. I have to get all this **** out of my garage.
Old Jul 27, 2005 | 12:43 PM
Default Re: NEED PIN OUTS!!! (brokenojoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke &raquo;</TD></TR><TR><TD CLASS="quote">If you have no luck at your local yard, IM me and I'll send you one. Just pay me shipping. I have to get all this **** out of my garage. </TD></TR></TABLE>
Okay, Thanks man!
j spec
Oct 23, 2006 07:36 PM
dat_flip
Apr 14, 2005 12:55 PM
hotteg04
Dec 22, 2004 01:02 PM
spiceisler
Dec 11, 2004 11:32 AM
HybridRexy
May 5, 2002 08:19 PM
