AC not working, compressor turning on off, on off, ect...??
Old Jul 12, 2005 | 02:19 PM
koondawg's Avatar
Default AC not working, compressor turning on off, on off, ect...??
I have a 2000 TL ,the ac compressor turns on and off, repeated every few seconds? Anyone know where to start??
Thanks
Old Jul 12, 2005 | 02:24 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: AC not working, compressor turning on off, on off, ect...?? (koondawg)
low on refridgerant (check pressure in system -may have a leak) or pressure switch prob's
Old Jul 12, 2005 | 02:34 PM
koondawg's Avatar
Default Re: AC not working, compressor turning on off, on off, ect...?? (Mr. B in Az)
I just filled it, the guage shows middle of full.
what are these probs you speak of?
Old Jul 12, 2005 | 04:49 PM
PrettyLude's Avatar
what kind of guage are you using when you are checking your freon levels? i hope its not the 19.99 gauge at autozone, you need a good set of pressure gauges
Old Jul 12, 2005 | 07:22 PM
koondawg's Avatar
Default Re: (PrettyLude)
Yes, it is from autozone, showed empty, filled it up some, now it is in the middle of full. It seems to do it on hotter days, yesterday it worked fine all day, not that hot, but today, almost 100* not working?? should I let some out?
thanks
Old Jul 12, 2005 | 11:39 PM
nevamind's Avatar
Default Re: (koondawg)
I"m not an A/C gurus, but I've seen my coworker having the same problem. Come to find out it cause by the automatic sensing switch, which turn the A/C compressor on and off automatically. Not too sure if your car have something similar though
Old Jul 13, 2005 | 07:46 PM
maxrpm's Avatar
Default Re: (nevamind)
sounds like my problem. The compressor would go on than few secs later go off again. My problem was that i used the wrong a/c oil in the compressor or too much oil. I had to evacate half of the freon already in the lines and put in new freon without the oil. It work good for a year now.
Did you use those freon with the oil mixed in the cans? I think honda use ND 8 oil (thats what is printed on the label on the a/c compressor). My car is a 95 integra
AtoZ
Apr 15, 2010 06:28 AM
M15
48
Jul 22, 2006 10:11 PM
dynamo
Jun 9, 2006 09:05 PM
Kevinarich
Apr 3, 2006 03:11 PM
91integraLSVTEC
Aug 22, 2005 08:18 PM
