Oxygen sensor #1???
Old Jul 12, 2005 | 01:57 PM
97exd16's Avatar
Default Oxygen sensor #1???
where is the oxygen sesor #1????
Old Jul 12, 2005 | 01:59 PM
EK k kay's Avatar
Default Re: Oxygen sensor #1??? (97exd16)
Somewhere on the exhaust manifold.
Old Jul 12, 2005 | 02:27 PM
97exd16's Avatar
Default Re: Oxygen sensor #1??? (chowmien)
ok this is the situation my check engine light has been on for the past 500 miles when i turn my car on it blinks once and i'm not sure but i think thats the oxygen sensor #1 so wut the hell is wrong?? i checked the sensor on the exhaust mani and it looks good and its deffinately connected so wuts wrong?? please help
Old Jul 12, 2005 | 02:43 PM
EK k kay's Avatar
When you first turn on the car the check engine light is supposed to come on then turn off after a few seconds. That is normal. If it stays on then you have to check the code.
Old Jul 12, 2005 | 02:47 PM
DumpedSi's Avatar
a solid blink is 10 and a short blink is 1 so if its long I think its the IAT sensor.. Chances are thast not it beucase I dont think those go bad.. I have a sensory if you're looking for one to replace yours with..
Old Jul 12, 2005 | 02:49 PM
97exd16's Avatar
Default Re: Oxygen sensor #1??? (Slammed Si)
when i turn the car on it comes on like its supposed to then shuts off for a second and then goes back on wut is that?
Old Jul 12, 2005 | 03:51 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97exd16 &raquo;</TD></TR><TR><TD CLASS="quote">when i turn the car on it comes on like its supposed to then shuts off for a second and then goes back on wut is that?
Go here: http://www.c-speedracing.com/faq/06.php
Then here: http://www.c-speedracing.com/faq/05.php
Old Jul 13, 2005 | 07:19 AM
97exd16's Avatar
"On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires."
there is no green cover under my passenger side dash!
Old Jul 13, 2005 | 08:09 AM
Dwight Schrute's Avatar
it's right by the glove box, it's tucked away a little, it's bright green
Old Jul 13, 2005 | 09:23 AM
EK k kay's Avatar
Default Re: Oxygen sensor #1??? (drewthomas14)
Just look for the blue or brown 2 wire plug.
Old Jul 16, 2005 | 05:42 PM
97exd16's Avatar
Default Re: Oxygen sensor #1??? (my head a plode)
theres a conector that has two wires going into it but there are like 10 wires going out of it and its under my passenger side tucked right on the post on the center console the rod that is right behind the radio and stuff its blue and yellow is this the right one??
Old Jul 20, 2005 | 04:02 AM
97exd16's Avatar
bump
Old Jul 22, 2005 | 10:42 PM
97exd16's Avatar
BUMP
Old Jul 26, 2005 | 10:17 AM
97exd16's Avatar
wtf ppl bump!
Old Jul 26, 2005 | 10:22 AM
blaze the chemi's Avatar
That is the worng connector that you are looking at. Look at
https://honda-tech.com/zerothread?id=1171263
In the first post you will see what you need to look at. Just search.
Good luck.
The CEL is supposed to blink once after it comes back on just to remind you that you have the CEL. Jump that think and then look to see what code you have. GL.
Old Jul 26, 2005 | 10:59 AM
DJ_CARY's Avatar
Default Re: Oxygen sensor #1??? (blaze the chemi)
if u have a 97 ex, that'll be an OBD-2
JUST GO TO AUTOZONE and "BORROW" the OBD2 READER for "FREE"
Usually it's a P0135 bank 1 sensor 1 code
That mean's it's before the cat or in the header itself
I just changed mine like 4 days ago...It's easy
Oh yeah make sure u warm up ur car before removing the 02 sensor....HEAT helps loosen the bolt "HEAT makes the metal expand or mandible"
Old Jul 26, 2005 | 11:58 AM
egsleepercivic's Avatar
if your car has less than 150k miles take it to the dealer and get it fixed for free, its a known issue I believe for 96-97's
Old Jul 26, 2005 | 11:59 AM
JDM-EJ1's Avatar
Default Re: Oxygen sensor #1??? (wadup)
On the left side of the exhuast manifold.
Old Jul 26, 2005 | 12:08 PM
Navid OG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">it's right by the glove box, it's tucked away a little, it's bright green</TD></TR></TABLE>
thats where it is... just find it take the two sides of a paper clip and put it in and watch the check engine light flash... long = 10, short = 1 then check what code it is... the way ur explaining it right now makes it sound like its the normal check engine light that comes on when u start any car
Old Jul 31, 2005 | 08:06 PM
97exd16's Avatar
Default Re: Oxygen sensor #1??? (Navid OG)
no its on all the time!!! i turn the ignition yeah it turns on like its supposed to then it turns off for a split sec then stays on all the time until i turn the car off there i explained it to a retard now you can read it and help me
scott1ct
Oct 28, 2013 02:26 PM
Kent in KC
Jan 7, 2008 01:08 PM
SjCiViCHB
May 1, 2003 01:20 AM
HATCHFREEK
Mar 19, 2003 10:32 AM
