Gaskets for rc310 Injectors
That is a picture for what I have. The top one has a rubber gasket on it, then the oem one next to it. The bottom has the rubber gasket off of it, and it is laying next to it with the oem one next to that.
Do I need both of those (oem and other) or just the one that is on the injector on top??
the oem one doesnt go around the injector like the one thats on the top injector, if i need to use the oem one, should i dremel it out to make it fit around, or is there a certain gasket i can buy somewhere that will fit correctly??
pic works for me.
i dont have the instructions, wish i did.
yeah i know about the o-rings, i am about to send them an email, i am talking about the injector to intake manifold part...
just put them On the injector, install in the Mani, turn on your car for fuel pressure and see if you have a leak. Thats what I did with my Rc's. Didnt have any leaks. Ive been running them for at least 4k miles on a BUILT b20vtec.
the ones i got were old, when everthing was bolted it was leaking (the top, smaller ones). I went to Honda and got the oem ones.
the base ones do much sealing, they just hold the injectors in place. I used OEM ones for them as well.
use oem rims for the top and bottom of the injector....thats what i used when i had my rc 310s and i didnt have any problems...the oem ring for the bottom of the injector is goint to fit kinda tight just so u know
