are these parts compatible?
Old Jul 12, 2005 | 11:21 AM
idriveadelsol7's Avatar
Default are these parts compatible?
off a 96-00 transmission parts such as the:
clutch
pressure plate
flywheel tranny
flywheel bolts
shift linkage
short shifter
clutch master cylinder
all mounts
going to be used on an automatic-manual conversion for a d15b7. those are d series parts by the way.
Old Jul 12, 2005 | 11:24 AM
Stoich EG2's Avatar
Default Re: are these parts compatible? (idriveadelsol7)
im going to say yes if they are all SOHC engines/transmissions
Old Jul 12, 2005 | 11:26 AM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Default Re: are these parts compatible? (Advan06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote">im going to say yes if they are all SOHC engines/transmissions</TD></TR></TABLE> x2
how much do you think they're all worth? 150$ sound good?
Old Jul 12, 2005 | 11:30 AM
Stoich EG2's Avatar
depending on what kind of clutch system you want to use, i'd say around $400 with new/used parts.
Old Jul 12, 2005 | 11:32 AM
they're all oem... i think he said they were new also.
Old Jul 12, 2005 | 11:34 AM
Stoich EG2's Avatar
start the bidding at $250 and happy buying
Old Jul 12, 2005 | 11:37 AM
thank you sir... appreciate your time and help &lt;3
techsynthesis
Oct 28, 2008 09:51 AM
lunch_box_4_life
Honda Civic (2001 - 2005)
Jan 24, 2008 02:29 PM
IntEGNYC
Oct 28, 2003 03:11 PM
Q-OnE
Oct 31, 2002 08:16 AM
