98 civic wont start need suggestions
Ok i have a B16 in a 98 civic sedan. When I turn the key nothing happens, I hear a relay click under the hood but the starter will not start the car. The starter works because if you take a wire and connect from the battery to the starter it starts right up. This also helps to rule out the main relay because the fuel pump is obviously working if the car is running. So at this point i am lost, it used to start and i checked all the connections i have recently undone but still nothing. If anyone has any ideas let me know. Thanks!
Re: 98 civic wont start need suggestions (TurboEclipse)
i'm not sure if i'm rite or not but check to see if ur starter's ground cable is connected, i had that problem in my civic. other than that i'm pretty much stumped
NoLimitCivic
05-09-2012 09:00 AM
