b16 oil leak between oil pan and block
Old Jul 11, 2005 | 10:24 PM
OneFire's Avatar
Default b16 oil leak between oil pan and block
I tighten downed all the bolts for the oil pan, a few of them were loose. Well I tighten downed all the bolts and the drain plug and it's still dripping oil. It's dripping out from between the block and the oil pan. Any idea how to fix the problem? and what I need?
Old Jul 11, 2005 | 10:27 PM
SOHC4life 96's Avatar
Default Re: b16 oil leak between oil pan and block (SOHC_Ek)
Get a new oil pan gasket, and don't tighten the **** outta the nuts/bolts when you put it back on. With the oil pan it IS possible to OVER tighten the nuts/bolts but it won't seem like they are tight.
Old Jul 11, 2005 | 10:32 PM
OneFire's Avatar
Default Re: b16 oil leak between oil pan and block (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Get a new oil pan gasket, and don't tighten the **** outta the nuts/bolts when you put it back on. With the oil pan it IS possible to OVER tighten the nuts/bolts but it won't seem like they are tight. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=538036
Next time i'll just post instead of searching
lazyxmofo
Mar 9, 2011 06:26 PM
tamadrumr88
Jan 13, 2010 04:26 PM
bopbop93030
Jul 4, 2009 06:40 AM
O16581724 5 2 5
13
Aug 2, 2005 04:49 PM
Chris93Si
Sep 1, 2003 08:37 AM
