b16 oil leak between oil pan and block
I tighten downed all the bolts for the oil pan, a few of them were loose. Well I tighten downed all the bolts and the drain plug and it's still dripping oil. It's dripping out from between the block and the oil pan. Any idea how to fix the problem? and what I need?
Re: b16 oil leak between oil pan and block (SOHC_Ek)
Get a new oil pan gasket, and don't tighten the **** outta the nuts/bolts when you put it back on. With the oil pan it IS possible to OVER tighten the nuts/bolts but it won't seem like they are tight.
Re: b16 oil leak between oil pan and block (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Get a new oil pan gasket, and don't tighten the **** outta the nuts/bolts when you put it back on. With the oil pan it IS possible to OVER tighten the nuts/bolts but it won't seem like they are tight. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=538036
Next time i'll just post instead of searching
bopbop93030
07-04-2009 06:40 AM
O16581724 5 2 5
13
08-02-2005 04:49 PM
