civic radiator problem HELP
I'm having problems with my radiator cooler, i think. Its so weird... I reffiled my radiator antifreeze coolant to full 5 months ago, and it has not gone down whatsoever, not even a milimeter. Can anyone help me or have suggestions or comments of what the problem is or what i can do to fix it. Thanks. I appreciate all the help.
Modified by theeogflip at 8:22 AM 7/12/2005
huh??..whats your problem?...that the coolant hasn't gone down?...why would you want it to go down...theres a reservoir that holds the coolant and that goes up and down when driving/sitting
what he said... coolant shouldnt go down too much if at all... if it is going down, then you have a head gasket leak or some kind of leak. The overfil tank is there to help out with any overfill coolant.
i mean.. the reservoir tank hasn't gone down a bit.... since i got the car 4 or 5 months ago. Doesn't the reservoir tank with the antifreeze go down a little after that long of use of car? The reservoir tank is still on the full line just like it was 5 months ago. Is that abnormal?
