OBX Throttle Body Spacer
Old Jul 11, 2005 | 08:22 PM
Jiggles's Avatar
Default OBX Throttle Body Spacer
I purchased an OBX Throttle Body Spacer for a 96 Civic DX the other day and installed it as soon as it arrived in the mail. After installation I noticed when I started up the car the engine is pulsating now I thought maybe the Ebay seller sent the wrong throttle body gasket . Well I ordered two OEM ones from Advance and installed the thing again and its still doing it. Any suggestions of what I should try or do before I send it back? Thanks for any help you can give.
Old Jul 11, 2005 | 08:42 PM
SOHCmaster's Avatar
why did you even buy it for ?
Old Jul 11, 2005 | 09:41 PM
aemciv's Avatar
make sure you have the gasket on correctly, my buddy removed his TB to install a new IM and installed the gasket backward and he had a vaccum leak.
prose
Old Jul 11, 2005 | 10:19 PM
Jiggles's Avatar
Default Re: (aemciv)
Ok so I took the throttle body spacer off and hope I can get my money back from the replies I have realized I made a poor decision on what I picked. The new problem is the TB spacer is off and my engine is still doing the same thing. The only thing I can think is that when everything was getting a bath I dropped the butterfly so maybe that has something to do with it? Or like you said the gaskets backwards.
Old Jul 11, 2005 | 10:24 PM
menkio's Avatar
Default Re: (Jiggles)
did you unplug anything... like the tps/map sensor, if so try switching them
Old Jul 20, 2005 | 11:34 AM
aemciv's Avatar
you have a vaccum leak somewhere you need to find it. double check everything. I think you need to buy a new gasket everytime you take the TB off. I was just thinking if you have a TB spacer you would probably need two gaskets one against the TB to the spacer and one between the spacer and the IM. did you?
prose
Old Jul 26, 2005 | 05:07 PM
andrew_white_95's Avatar
Default Re: HELP PLEASE
I am in the same situation... I have a JDM D15B that was running fine until I installed the OBX throttle body spacer. It would rev from around 1000 RPM to 3000 RPM, now I have removed it and its still doing the same thing. This isn't a vaccum problem, the gasket is fine and the bolts are tightened. Also, I did unplug the MAP sensor, but I don't THINK that has anything to do with it. Please help me out if you can... thanks!
Old Jul 26, 2005 | 05:41 PM
Default Re: HELP PLEASE (andrew_white_95)
BTW, I'm using the IM from my blown D16Z6, but that shouldn't matter b/c it was running fine before I put the TBS on...
Old Jul 26, 2005 | 05:50 PM
xEnderx's Avatar
YOu gotta give the comp time to adjust.....did you drive it around for 20 minutes or so?
Old Jul 26, 2005 | 06:17 PM
kaiba's Avatar
Default Re: OBX Throttle Body Spacer (Jiggles)
What does throttle body spacer actaully do?
Old Jul 26, 2005 | 06:18 PM
xEnderx's Avatar
Default Re: OBX Throttle Body Spacer (kaiba)
Increases the effective lenght of the intake runners.....sort of. It's the same idea as a spacer on a carb'd motor.
Old Jul 26, 2005 | 06:30 PM
Default Re: OBX Throttle Body Spacer (xEnderx)
I drove it around for about 20 minutes and it did the same thing... not as bad though... jumps from about 1500 to 2500 instead of 1000 to 3000...is it safe for me to be driving it? it runs fine as long as I don't let it drop down to 1000 RPM
Old Jul 26, 2005 | 06:37 PM
mestizo's Avatar
Default Re: OBX Throttle Body Spacer (andrew_white_95)
did u disconnect the coolant lines that go thru the the throttle body or the IACV? if so u have a bubble in that part of the cooling system that is causing the IACV to pulsate, since its the coolant that makes it open and close at certian times.
Old Jul 26, 2005 | 07:13 PM
madcrossover's Avatar
I had the OBX Throttle Body spacer on my 95 civic and it did the same thing, I took it to a shop after removing the spacer and they said it was the Gasket. So the guy made a new one and now its fine. Without spacer!
Obx Throttle Spacer
Old Jul 26, 2005 | 07:27 PM
ABK's Avatar
ABK
Default Re: OBX Throttle Body Spacer (madcrossover)
spacers are waste of money.
PRIMITIVEALLMOTOR
Engine Management and Tuning
Aug 9, 2008 05:21 PM
chiefb26
22
Apr 18, 2008 05:32 PM
blue2000em1
45
Dec 1, 2007 12:09 AM
maximedx
Aug 17, 2007 02:11 AM
x00gsr
Oct 25, 2004 07:46 PM
