valve clearance on ls/vtec.... (shaved head)
Ok here it is.. i just built a ls/vtec motor... after the build i found out the head had been shaved 60 thousands .... i have 11.1 compression pistons in the block ..... The compression should be about 12.1.1.. what would be the biggest cam i can run in it??? i know i can clay it.. its just i dont want to buy a set of cams and the i have a valve clearence problem....
