F/S H23a Short Block details inside
I'm selling a 1992 Prelude Si H23a short block. Has 160,000 miles
Included with the block is the following
I basically just unbolted the head and the accessories from the block. Everything else is there. The end of the crankshaft where the timing belt goes has the woodruf key slot damaged which caused the timing belt pully to spin on the end of the crankshaft.
This block would be good for H22a crank swap or you could replace the crank with another F22/H23 crank. I have not checked the bearing surfaces as I have not opened up the block. I can check into this for serious offers.
I will post pics soon.
Please email me at pete_s@bellsouth.net if you are interested
Buy with confidence as I am the owner of http://www.pspectuning.com and you will get exactly what is described.
Thanks
Thanks
Sinner
Sep 9, 2004 08:03 PM
BoostedH23a1
Feb 8, 2004 05:46 PM
Charlie Moua
Jun 1, 2002 04:39 PM
