Couple EF problems
Old Jul 11, 2005 | 07:10 PM
EFB16aJP's Avatar
Default Couple EF problems
I have a 91 hatch with a semi built jdm b16. Ever since I bought the car, I have to let it warm up before it will run right...hot or cold. That is one of the problems. Then I have a fuse that keeps blowing. It is the one for the instrument panel and the taillights, Maybe somebody can help me. By the way it is for sale.
Old Jul 11, 2005 | 07:16 PM
Crx Jimmy's Avatar
Default Re: Couple EF problems (EFB16aJP)
the fuse that blows for instrument lights and tail lights usually can be traced back to a bad radio install, usually the wire that dims the face is shorting intermittently or not hooked up at all to the deck and shorts out intermittenly
Old Jul 11, 2005 | 07:19 PM
EFB16aJP's Avatar
Default Re: Couple EF problems (Crx Jimmy)
Well the fuse just started blowing last week. I have had the car since last december. Could that still be the problem?
Old Jul 12, 2005 | 01:03 AM
Twilight's Avatar
Check the grounds behind the instrument panel. Double check the wires. If they're old ones, check them all and carefully.
Check out the cigarette lighter wires too.
Old Jul 13, 2005 | 01:32 PM
EFB16aJP's Avatar
Default Re: Couple EF problems (Twilight)
What about why I have to let it warm up everytime before it runs right without shutting off?
Old Jul 13, 2005 | 02:01 PM
Suck my DX's Avatar
r u throwing any codes...either ur iacv is no good or is clogged up...take it off and clean it....make sure that there is no open in the iacv wiring as well...
Old Jul 13, 2005 | 02:13 PM
JIDUM_Undercover's Avatar
theres a short in the wiring for the cluster my friends hatch was doing the same thing. And the motor is more then likely a clogged iacv
tidalwavez
Jan 12, 2011 12:24 AM
Dru-Si
Mar 21, 2010 06:12 PM
delslow302
Apr 12, 2009 03:04 PM
EF4lyfe
19
Sep 27, 2004 08:43 AM
DropSquadCivic
Sep 11, 2003 10:00 PM
