random noise while driving
Old Jul 11, 2005 | 05:56 PM
Jaysun's Avatar
Default random noise while driving
i keep hearing a click sound when i'm turning or going over bumps...not sure whats going on, its coming from the rear of the car but not from wheels/susp. any ideas would be great
Old Jul 11, 2005 | 09:45 PM
Jaysun's Avatar
Default Re: random noise while driving (QuikJaysun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun &raquo;</TD></TR><TR><TD CLASS="quote">i keep hearing a click sound when i'm turning or going over bumps...not sure whats going on, its coming from the rear of the car but not from wheels/susp. any ideas would be great</TD></TR></TABLE>
Old Jul 11, 2005 | 10:58 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
usually a click while turning is the CV joint on its way out, but if you say it's from the rear then it's probably a loose suspension piece. Have you recently changed any part of the suspension? Also check under the carpet in the trunk for any crap rolling around. good luck.
Old Jul 12, 2005 | 02:47 AM
Jaysun's Avatar
Default Re: random noise while driving (2000psi)
no changes, its def cming from the back
Old Jul 12, 2005 | 11:45 AM
Jaysun's Avatar
any1 else?
Old Jul 12, 2005 | 12:02 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">usually a click while turning is the CV joint on its way out, but if you say it's from the rear then it's probably a loose suspension piece. Have you recently changed any part of the suspension? Also check under the carpet in the trunk for any crap rolling around. good luck.</TD></TR></TABLE>
I agree.
Old Jul 12, 2005 | 09:30 PM
2000psi's Avatar
Default Re: random noise while driving (walker111)
have you done any work that could cause the sound??? check the body panels and the side skirts for looseness, could even be your muffler hitting something...just jack it up and get dirty
problematic
Sep 10, 2008 07:19 AM
yuning83
Honda S2000
13
May 23, 2008 07:48 AM
XyKo
Suspension & Brakes
Aug 30, 2005 07:13 AM
crx_lady
Sep 30, 2004 10:05 AM
shipsaeki
May 28, 2003 07:13 PM
