random noise while driving
i keep hearing a click sound when i'm turning or going over bumps...not sure whats going on, its coming from the rear of the car but not from wheels/susp. any ideas would be great
Re: random noise while driving (QuikJaysun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun »</TD></TR><TR><TD CLASS="quote">i keep hearing a click sound when i'm turning or going over bumps...not sure whats going on, its coming from the rear of the car but not from wheels/susp. any ideas would be great</TD></TR></TABLE>
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
usually a click while turning is the CV joint on its way out, but if you say it's from the rear then it's probably a loose suspension piece. Have you recently changed any part of the suspension? Also check under the carpet in the trunk for any crap rolling around. good luck.
cool guy name
Re: random noise while driving (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi »</TD></TR><TR><TD CLASS="quote">usually a click while turning is the CV joint on its way out, but if you say it's from the rear then it's probably a loose suspension piece. Have you recently changed any part of the suspension? Also check under the carpet in the trunk for any crap rolling around. good luck.</TD></TR></TABLE>
I agree.
I agree.
Re: random noise while driving (walker111)
have you done any work that could cause the sound??? check the body panels and the side skirts for looseness, could even be your muffler hitting something...just jack it up and get dirty
problematic
09-10-2008 07:19 AM
crx_lady
09-30-2004 10:05 AM
