OBD 2 B series into an EG...
Old Jul 11, 2005 | 05:55 PM
_Cyclone_'s Avatar
Default OBD 2 B series into an EG...
I want to throw a B18B into my EG... if I get an OBD 2 B18B, what wiring issues will I run in to?
Old Jul 11, 2005 | 05:57 PM
Deemeetree's Avatar
Electrician
Have you checked out the FAQ thread on top of the page?
The turbo D16Z6 isn't enough huh?
Old Jul 11, 2005 | 06:01 PM
Reid's Avatar
Global Moderator
Default Re: OBD 2 B series into an EG... (_Cyclone_)
The OBD2 engine wiring harness plugs into the OBD1 chassis plugs.
Just run an OBD1 ECU.
Old Jul 11, 2005 | 06:08 PM
eg6_rick's Avatar
keep your stock eg engine hardness,
-you will need to get OBD1 b-series dizzy
-you will need OBD1 alternator or you can splice the alt eg hardness and OBD2 hardness that came with your swap and color match them to plug into the OBD2 alt or vice versa.
-and you need OBD2- OBD1 ECU conversion hardness or get a OBD1 LS ECU
i think thats the wiring issues you'll run into... but there might be more to it, if i can think of i'll get back to ya... GL with the swap...LSVtec Boost is better !
-> eg6_rick
_Cyclone_'s Avatar
Default Re: OBD 2 B series into an EG... (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked out the FAQ thread on top of the page?
The turbo D16Z6 isn't enough huh?</TD></TR></TABLE>
Yes I checked the FAQ's... It was a turbo Y8 and I sold it today. I'm starting something new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">The OBD2 engine wiring harness plugs into the OBD1 chassis plugs.
Just run an OBD1 ECU. </TD></TR></TABLE>
That seems almost too good to be true! I was going to grab an OBD 1 P75 or something. If the chassis plugs are the same, I shouldn't have any wiring issues if the OBD 2 B18's harness is intact?
Old Jul 11, 2005 | 06:23 PM
eg6_rick's Avatar
no thats not true the plugs on the dizzy and the alt are not plug an play and they will not fit...trust me i did the swap my self and had to modify the wiring to fit... the ECU hardness wont fit as well.
Old Jul 11, 2005 | 06:46 PM
Reid's Avatar
Global Moderator
Default Re: OBD 2 B series into an EG... (eg6_rick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">keep your stock eg engine hardness,
-&gt; eg6_rick </TD></TR></TABLE>
Just use the OBD2 engine wiring harness, that's much cheaper than sourcing all of those OBD1 parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">no thats not true the plugs on the dizzy and the alt are not plug an play and they will not fit...trust me i did the swap my self and had to modify the wiring to fit... </TD></TR></TABLE>
That's why you use the OBD2 engine harness!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">the ECU hardness wont fit as well. </TD></TR></TABLE>
An OBD1 LS ECU will plug right into an OBD1 chassis harness.
Old Jul 11, 2005 | 06:47 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Cyclone_ &raquo;</TD></TR><TR><TD CLASS="quote">I shouldn't have any wiring issues if the OBD 2 B18's harness is intact?</TD></TR></TABLE>
Correct.
Old Jul 11, 2005 | 06:48 PM
Relic1's Avatar
ok, it's been covered all ready a lot of times but here yah go.
get the OBD2 engine harness, keep your OBD1 chassis harness.
plug them together at the shock towers, move a couple wires. Your done.
that's how I did mine, '00 teg into '92 civic. I moved three wires total and I have a VX. (which requires the O2 wire to be moved, DX/EX/CX do not)
Old Jul 11, 2005 | 07:13 PM
eg6_rick's Avatar
An OBD1 LS ECU will plug right into an OBD1 chassis harness.</TD></TR></TABLE>
well, yea if the OBD2 hardness came with the swap then ignore what i said earlier.
Old Jul 12, 2005 | 01:06 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">well, yea if the OBD2 hardness came with the swap then ignore what i said earlier.</TD></TR></TABLE>
It's harness.
Old Jul 12, 2005 | 04:33 AM
_Cyclone_'s Avatar
Correct. </TD></TR></TABLE>
Good. And if the OBD 2 harness is not intact, I'm going to use the OBD 1 CX harness and splice the plugs that I need (dizzy, injectors, alternator, etc) from the cut up OBD 2 harness. The jobbers usually cut the harnesses at or near the shock towers, so I should still get all the plugs I need anyways.
Alright, I'm good. Thanks!
Old Jun 25, 2023 | 01:09 PM
ethanjames1's Avatar
im currently doing a swap of a b18c4 into my 95 eg coupe. the swap I got came out of an EK that had been swapped. I'm wondering what i'll need to get mine running and with vtec. any help would be appreciated
jdmanglerking
Mar 29, 2010 02:10 PM
beginmyhonda
Jan 11, 2010 05:02 PM
Pete_SI
11
Apr 14, 2007 12:00 AM
mugenracer
Mar 3, 2005 05:19 PM
Paulnsx
Jan 12, 2005 01:09 PM
