Eibach Sportlines sagging?
Old Jul 11, 2005 | 02:34 PM
Tru's Avatar
Tru
Default Eibach Sportlines sagging?
I installed my Koni Red Suspension Kit back in the middle of June. Now it seems like my passenger side is lower than my drivers side. drivers side has about 1 finger of wheel gap, but passengers side has less than one(have to put my finger pointed up to get inbetween tire/fender) passenger side is almost tucking, but drivers side has a bit of gap. Will it settle to itll be the same, or are my springs sagging?
Old Jul 11, 2005 | 02:35 PM
EK k kay's Avatar
Default Re: Eibach Sportlines sagging? (Tru)
Was it like this before putting on the new suspension?
Old Jul 11, 2005 | 02:43 PM
Tru's Avatar
Tru
not that i know of...but its hard to tell on stock suspension. im pretty sure it was all even though before i put on the Koni RSK
Old Jul 11, 2005 | 04:00 PM
disposable's Avatar
i have the same thing happen to me.... except mine is the drivers side :S yes it sucks. i got a 2 finger gap on one side, and a 1 finger gap on the drivers. i changed struts, sportlines seemed to be good. i even tried putting the drivers side setup on the passengers side and visa versa.. still the drivers side. I am pretty positive that for me.. its the trailing arm bushing thats warn too much and it making me sag... i can see through mine. you should check yours out too...
Old Jul 11, 2005 | 04:18 PM
96CivicBoostCoupe's Avatar
Default Re: Eibach Sportlines sagging? (disposable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disposable &raquo;</TD></TR><TR><TD CLASS="quote">i have the same thing happen to me.... except mine is the drivers side :S yes it sucks. i got a 2 finger gap on one side, and a 1 finger gap on the drivers. i changed struts, sportlines seemed to be good. i even tried putting the drivers side setup on the passengers side and visa versa.. still the drivers side. I am pretty positive that for me.. its the trailing arm bushing thats warn too much and it making me sag... i can see through mine. you should check yours out too...</TD></TR></TABLE>
I had the same problem with my civic, Energy suspension master bushing kit fixed me all up and now im all even
Old Jul 11, 2005 | 05:57 PM
moto1320's Avatar
Default Re: Eibach Sportlines sagging? (96CivicBoostCoupe)
trailing arm bushings most of the time. They get hammered over time in stock configuration, lowered it happens much faster. Energy's are only a little more than OEM and in some cases cheaper.
Old Jul 12, 2005 | 05:50 PM
Tru's Avatar
Tru
how will trailing arm bushings help if its the front suspension?
Old Jul 12, 2005 | 08:08 PM
Tru's Avatar
Tru
anybody?
Old Jul 13, 2005 | 03:48 AM
moto1320's Avatar
Default Re: (Tru)
They won't effect the fronts, they usually effect the rear and if bad enough can make a wholeside of a car look lower. Did you count the threads? Your spring perches haven't moved?
hatchattack02
Suspension & Brakes
10
May 5, 2011 02:12 PM
riceforlife
Dec 31, 2007 02:00 AM
froger
Dec 31, 2007 01:42 AM
hondastrtracr
15
Aug 5, 2007 08:29 PM
