how do you call that thin thats hold the engine and tranny togather.?
hello everybody...
how do you call that aluminum piece that we need to remove to get to the passanger side oil pan bolts?
im askin this cause i need to buy one for my b16a2.
best regards moshik galimidi
i just wanna make sure that were talikng about the same thing....
is it the flywheel cover or is it the flywheel inspection cover or are thay actualu the same thing?
this is part of the broken peice..... bolted on to the engine.
Modified by RACEPAK at 2:28 PM 7/11/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">you dont' need this piece...i personally never put them on my engines</TD></TR></TABLE>
r u sure....??
i know that its not somthing sirius. but isnt removing it will cause stress on the engine and the trenny?
r u sure....??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
r u sure....??
i know that its not somthing sirius. but isnt removing it will cause stress on the engine and the trenny?</TD></TR></TABLE>
damn dude a dictionary would do you some wonders. LOL
but seriously i dont think you need these parts. i just used them as a stand when i put my blocks on the floor
r u sure....??
yo can still put the cover on without that bracket yano. Ive also ran a few cars without the covers . It just helps from getting rocks or something up in there but, Ive never heard of that happening
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">
yeah i need to use that spell check more often.... lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FortunateFool. »</TD></TR><TR><TD CLASS="quote">yo can still put the cover on without that bracket yano. Ive also ran a few cars without the covers . It just helps from getting rocks or something up in there but, Ive never heard of that happening</TD></TR></TABLE>
ok thanx
ok thanx
That is a "stiffener" bracket (#9 & #10 in the picture below). There are two that connect the cylinder block to the transmission, and help reinforce the connection between the two. They are around $35 each from Honda, but you can buy them here for about $10 less. Make sure you know which one you need before you order it because each one is different...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">That is a "stiffener" bracket (#9 & #10 in the picture below). There are two that connect the cylinder block to the transmission, and help reinforce the connection between the two. ]</TD></TR></TABLE>
so are thay really neseccery?
are those brackets similar for all B16's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">it's there so your motor dont make noise and vibration</TD></TR></TABLE>
are those brackets similar for all B16's? </TD></TR></TABLE>
How so ? I dunno how many motors I've had without them for years ...Yes its an easy and cheap part to replace but I wouldn't say its necessary
Hatch It
Jun 7, 2005 02:08 PM
stripes777
Oct 11, 2004 01:28 PM
Loveless
Oct 11, 2003 07:23 AM
