steering colum replacement????
well i need to replace my steering colum due to theft...welll attemt to steal...
HOW hard is it??
any tips???
thanks and also can i get a new key made from the dealer wiht my vin number, so i can lock my doors.
HOW hard is it??
any tips???
yea you probably just need the ignition cyl. which will come with a new ignition key, your doorlocks will use your original key so you'll have 2 keys. Replacing the whole ignition assembly is pretty easy all you need are just the basic tools, i just did my first one last week and it wasn't hard at all.
i need to do the whole colum the theaf drilled out my old ingition and punched out the steering wheel lock so i use a screw driver to start my car and take out the ecu fuse when i go in the city and ****
sucks ***
sucks ***
I replaced my entire column (went to tilt) in about 2 hours. and that's with swapping the key cylinder out to keep one key.
The hardest part is keeping the wheel centered.
The Helm manual lists what to do perfectly.
SoCalCivic498
Apr 20, 2015 08:37 PM
Flamenco-T
Nov 19, 2002 07:32 PM
