one wheel spins when car is lifted and put in first gear normal?
Old Jul 11, 2005 | 09:26 AM
crx_ef8's Avatar
Default one wheel spins when car is lifted and put in first gear normal?
is my tranny **** up? i have no lsd and it grinds on 3rd gear
oh and my axles makes a clunking noise when turning left and sometime goin straight
Old Jul 11, 2005 | 09:49 AM
RACINTWEEK's Avatar
Default Re: one wheel spins when car is lifted and put in first gear normal? (crx_ef8)
thats normal for a NON LSD car,
but the grinding 3rd and clunking axle isnt.
you need to stop full throttle shifting into 3rd and adjust your clutch cable
and you need a new axle, you are supposed to replace it at teh first sign of clicking while turning, beoing as it clicks going straight means you driven on it fucked up for a while and its prob gonna break completely soon
Old Jul 11, 2005 | 10:05 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">one wheel spins when car is lifted and put in first gear normal? </TD></TR></TABLE>
normal. its the tranny fluid just moving around putting a slight force on the non-engaged gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">is my tranny **** up? i have no lsd and it grinds on 3rd gear
oh and my axles makes a clunking noise when turning left and sometime goin straight</TD></TR></TABLE>
not normal.
Old Jul 11, 2005 | 11:00 AM
crx_ef8's Avatar
Default Re: one wheel spins when car is lifted and put in first gear normal? (Tyson)
which side do i need to replace ?
Old Jul 11, 2005 | 11:32 AM
Andy R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">which side do i need to replace ?
What has happened is likely your drive shaft boot around the joint ripped and you have lost lubricant and/or debree has gotten into the joint. Over time the lack of lubricant will put enough wear that will render the joint useless. The clunking is the result of this. Eventually the with enough wear the joint will become loose enough that it may bind and either shatter the joint or shear the shaft.
First just listen for which side its coming from. Its not unlikely in your case of negligence that both sides are bad. To confirm, you can jack up the front end and look for torn boots and play in the shaft from that joint. Replace damaged sides, the auto parts store will charge a core fee unless you bring them your damaged drive shafts. You will likely run into problems removing the shafts. That is probably a level 6 out of 10 job, and requires certain tools. I'm sure you can either read the manual or do a search for specifics on removing drive shafts.
Old Jul 15, 2005 | 03:42 PM
crx_ef8's Avatar
Default Re: one wheel spins when car is lifted and put in first gear normal? (Andy R)
nm fixed it, it was the right side axle.
i have to get jdm oem one
Old Jul 15, 2005 | 03:59 PM
ghonaherpalitis's Avatar
you fixed it?
why do you need another axle?
Kooner450r
Oct 28, 2005 08:32 AM
No2Pencil
Oct 17, 2005 05:17 AM
dorikingts
Apr 29, 2005 12:54 PM
ComingSoonNearYou
13
May 23, 2004 05:12 PM
crazy eyez killa
Nov 26, 2003 05:57 PM
