tranny fluid leaking from sensor. how to fix and what is the sensor called?
Old Jul 11, 2005 | 07:26 AM
coot_er's Avatar
Default tranny fluid leaking from sensor. how to fix and what is the sensor called?
I have a first gen b16 and i notice im leaking fluid for the sensor that is close to the clutch arm on the tranny. is this common and how do i fix it? should there be a washer or gasket or something between the bolt and the whole?
Old Jul 11, 2005 | 10:26 AM
coot_er's Avatar
Default Re: tranny fluid leaking from sensor. how to fix and what is the sensor called? (coot_er)
any ideas?
Old Jul 11, 2005 | 08:21 PM
coot_er's Avatar
any help?
Old Jul 11, 2005 | 08:24 PM
RCautoworks's Avatar
Sounds like the reverse sensor for the backup lights.
Drain the trans fluid, take sensor off, use teflon tape on the sensor. Install sensor and install fluid
Old Jul 12, 2005 | 07:17 AM
coot_er's Avatar
Default Re: tranny fluid leaking from sensor. how to fix and what is the sensor called? (90blackcrx)
so there is not washer that im missing? i can see a while thing (seal?) that is seated inside the houseing. im just surprised something wouldn't cover it up completely.
Old Jul 12, 2005 | 07:56 AM
ILcrxsi1's Avatar
I tell doctors what to do
i know the d series transmissions have a washer and the service manualy says to replace it everytime it is removed, so i'm guessing it's just some sort of crush gasket or somthing. i'm not sure about the b series though.
Old Jul 12, 2005 | 10:52 AM
coot_er's Avatar
Default Re: (90sirex)
anybody else know anything about this crush washer for a first gen b16? does it exist? part no.?
Old Jul 12, 2005 | 10:56 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yes, it's a crush washer, much like you find on your oil pan drain bolt.
#22 in this picture:
Lists is $0.28.
Old Jul 12, 2005 | 11:06 AM
CRX Toad's Avatar
Default Re: (DaX)
I'd have to say replace the crush washer and use teflon tape.
Old Jul 12, 2005 | 12:30 PM
coot_er's Avatar
Default Re: (CRX Toad)
i dont think i have the washer. thats prolly my problem
Old Jul 12, 2005 | 12:33 PM
coot_er's Avatar
Default Re: (coot_er)
not to sound like a dumbass but is it the same part as a crush washer for a b16? ive never replace my oil pan washer so maybe i'll pic up a few if they're all the same part. any ideas if they are the same and what the part no are?
Old Jul 12, 2005 | 12:34 PM
turbotommy's Avatar
yeah it should be...another honda standard
cnovak1110
Honda Civic (2006 - 2015)
Apr 25, 2017 11:30 PM
mayfly
May 31, 2010 05:58 AM
reeder321
Mar 16, 2010 02:12 PM
andrewsmith85
19
Jul 25, 2008 11:58 AM
