Car Doesnt Run w/ ctr pistons
Old Jul 10, 2005 | 06:47 PM
freakasis's Avatar
Default Car Doesnt Run w/ ctr pistons
i have a stock ls motor, i just added ctr pistons and arp rod bolts. now it doesnt run. it will start and run like **** for a little while, and if i give it gas, it dies. i got a cyk code out of it once, but other than that no codes. when it is running if you unplug the map sensor it doesnt stall, i know that it would normaly. i borrowed some spare parts from a friend, figured i would try replacing the electronics and see if that helped, it didnt. i tried a new ecu, coil/ignighter, map sensor. i have spark and fuel and the timing is all lined up, compression test is 210 accross the board. i have been told that i might need to adjust the timing to compensate for the ctr's. is this correct? if so can i do if by adjusting the teeth or will i need adjustable cam gears? any help would be greatly appriciated. i now have to borrow a car to get around. thanx
Old Jul 10, 2005 | 08:06 PM
crx4life2002's Avatar
Default Re: Car Doesnt Run w/ ctr pistons (freakasis)
sound to me like your timing is off?
Old Jul 10, 2005 | 08:34 PM
freakasis's Avatar
Default Re: Car Doesnt Run w/ ctr pistons (crx4life2002)
well, that was my first thaught but i have checked and rechecked it, and its dead on. but do i need to adjust it differently because of the new pistons? someone told me that i may have to. can someone confirm this? or should the stock timing be ok for this setup? if the stock timing is ok what else should i check?
Old Jul 11, 2005 | 08:58 AM
freakasis's Avatar
bump
Old Jul 13, 2005 | 12:10 PM
DaveF's Avatar
Default Re: (freakasis)
maybe you switched the tps and map plugs by accident???
Old Jul 14, 2005 | 03:17 PM
freakasis's Avatar
thaught of that too....switched and no differance.
Old Jul 29, 2005 | 03:28 PM
nitroeg's Avatar
now the timimg is dead on right your not 180 off are you
Old Jul 29, 2005 | 03:47 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
^^word. take off your distributor and turn it 180 degrees.
bmwe362006
73
Nov 14, 2009 06:35 PM
onewayoutcity
May 25, 2009 01:06 PM
nolicense526
Sep 16, 2008 07:59 AM
Death_to_Thieves
May 29, 2003 05:13 PM
blazin
Nov 16, 2001 06:05 PM
