torn axle rubber cover
Old Jul 10, 2005 | 03:52 PM
kinkyintegra's Avatar
Default torn axle rubber cover
well my control arm ball joint seperated so today i tried rolling it across the street and i guess all the movement of the suspension because it was not hooked up to the control arm made it move back and forth. so i was taking off the control arm and i noticed my axle had popped out of the part closest to the engine. i also noticed that the rubber cover was torn, well i was able to put the axle in fine, nothing was messed up on the connecting parts but just the boot is torn so some grease had come out. is it safe to drive the car with a torn cover.....can i replace the cover? if so, some sites would be very helpful! thanks for your help....these forums are awesome
Old Jul 10, 2005 | 07:47 PM
integra-evan's Avatar
Get that CV Boot replaced ASAP. The joint needs that grease to function properly.
Old Jul 10, 2005 | 07:52 PM
AllMotorDan's Avatar
yeah like integra-evan said get a cv boot asap
Old Jul 10, 2005 | 08:36 PM
s2kkid's Avatar
Default Re: (SpoonSirG)
the boot cost like 10 bucks with a nice new pack of grease and a new clamp...
The one closest to the engine is the easier one to do anyway.. So give it a shot
Old Jul 12, 2005 | 11:44 AM
Default Re: (vtecluder97)
so the boot i described would be the inner boot right?
Old Jul 12, 2005 | 02:16 PM
Default Re: (kinkyintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra &raquo;</TD></TR><TR><TD CLASS="quote">so the boot i described would be the inner boot right?</TD></TR></TABLE>
yup
Old Jul 13, 2005 | 10:47 PM
Default Re: torn axle rubber cover (kinkyintegra)
how hard is it to replace the inner boot, since its torn could i just grease up the boot, slide it on the axle, connect the axles and then tighten the clamp?
Old Jul 13, 2005 | 11:00 PM
six_speed's Avatar
you will need an air gun or it's going to be more painful to change the cv boot unless you like working under the car.
tools that are needed:
ball joint puller or pickle fork
32mm socket to unbolt the axel nut (impact gun recommended
needle nose pliers
~the inner hub has 3 roller bearings on the shaft that just slides out of the inner hub
~remove the bearings and clean up the top portion of the shaft
~remove c-clip with a metal pick (or anything that's small and pointy/strong
~pull out the piece that holds the bearings
~slide boot in
Old Jul 14, 2005 | 08:17 AM
Default Re: (six_speed)
i have a seperated ball joint so i figured id fix the cv boot first and then put in the new control arm with ball joint, i dont mind working under the car, i really dont want to bother taking off the axle right now, it seems as tho i can slide the boot on the axle and the part closer to the engine and then connect the axles....idk you tell me
Old Jul 14, 2005 | 08:18 AM
JDM-EJ1's Avatar
Default Re: (integra-evan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-evan &raquo;</TD></TR><TR><TD CLASS="quote">Get that CV Boot replaced ASAP. The joint needs that grease to function properly.</TD></TR></TABLE>
Yes, this is one part that can't afford to be damaged for long while you drive on it. A tear will cause the grease to leak and it can damage the axel.
Old Jul 14, 2005 | 08:32 AM
Default Re: (JDM-EJ1)
well ever since the ball joint seperated the car has been sitting there, but from my stupidity about a week ago the axle pulled out and tire the boot in half, the joint is basically two ends with these things that come together and the boot with grease goes around it? so the car hasnt been driven in about 2 weeks, and its just sitting there in my yard waiting to be fixed...
Old Jul 14, 2005 | 08:37 AM
six_speed's Avatar
~remove roller bearings,c-clip, and the bearing holder(probably have to be forec out)
~then you can slide on your new cv boot
~just put new grease inside the cv boot
Old Jul 14, 2005 | 09:29 AM
i know this is probaly getting annoying...sorry....uhh so the roller bearings are inside the boot? and once i remove them i should be able to slide on the boot and then put the roller bearings in? im confused as to where the bearings are...
Old Jul 14, 2005 | 09:42 AM
blissdev's Avatar
how much would this cost to get done by a mechanic?
Old Jul 15, 2005 | 08:42 AM
blissdev's Avatar
Default Re: (blissdev)
*bump*
I'd really like to know the answer to this.
Old Jul 15, 2005 | 09:30 AM
Leithen's Avatar
honda charged 153$ to get your outer cv boots replaced
Old Jul 15, 2005 | 11:16 AM
six_speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra &raquo;</TD></TR><TR><TD CLASS="quote">i know this is probaly getting annoying...sorry....uhh so the roller bearings are inside the boot? and once i remove them i should be able to slide on the boot and then put the roller bearings in? im confused as to where the bearings are...</TD></TR></TABLE>
the roller bearings are inside the (inner hub) the boot just keeps the grease insde to lub the bearings/hub to prevent metal to metal contact.
first there is the shaft...then there is the rolling bearing holder (y shape and it slides on to the shaft, after that there is a c-clip that holds the roller bearing holder to the shaft. the roller bearings go on to each part that sticks out of the Y and the whole thing goes in to the inner hub.
if you don't understand a part then ask.
Old Jul 15, 2005 | 12:10 PM
alright so i looked inside and i pulled out this bearing with 2 rings in it, and the inner ring moves around....so basically this is what was inside my inner boot: axle with 3 ***** at the end, that wierd bearing, and then a big thing with 3 *****...so is there more than one of these bearings? because this is all i found in there....the c-clip is on the outside of the boot?
Old Jul 15, 2005 | 12:19 PM
it also seems impossible to do without taking the axle nut off and pulling out the axle and sliding it on......please tell me theres a way of doing it without that....another question is on the end of the axle coming from the caliper where that 3 **** thing is, is it possible to take that off the axle, slide on the boot, put it back on and then do the rest?
Old Jul 15, 2005 | 12:43 PM
six_speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra &raquo;</TD></TR><TR><TD CLASS="quote">alright so i looked inside and i pulled out this bearing with 2 rings in it, and the inner ring moves around....so basically this is what was inside my inner boot: axle with 3 ***** at the end, that wierd bearing, and then a big thing with 3 *****...so is there more than one of these bearings? because this is all i found in there....the c-clip is on the outside of the boot?</TD></TR></TABLE>
ilook at the end of the shaft that goes in to the inner hub...there is the c-clip right before the roller bearing holder. you'll have to remove it first before you can pound out the roller bearing holder. also the roller bearing can be easily slide out.
Old Jul 15, 2005 | 01:26 PM
there is only one roller bearing, right? sixspeed, could you maybe give me your aim sn so i could ask you a couple more questions because you really know what youre talking about.....thank you
Peteypablo17
Transmission & Drivetrain
Feb 10, 2013 05:31 PM
Jimster480
Jan 22, 2010 10:58 AM
shorty0o29
Feb 24, 2004 09:31 PM
jaxle
Jan 8, 2004 02:56 AM
