wiring harness for h22? install?
need to know where to get one in the frederick md area or online... any sugestion? also anyone know a good spot to do the install in frederick county md? i lack the tools to do it myself
Um, you don't buy a harness. You modify the existing one. Unless you are talking about a obd2 to obd1 harness. Then search on here for one. Go to http://www.accordinglydone.com go under tech. Everything you need to know to wire and inatall your h22 is in there. If you can't do it after reading that, hire it out.
If you are installing it into your 96 lx you just use the wiring harness from your lx motor then add the wires for the VTEC, knock sensor, intake air bypass. There may be one more but I think that is it. And as freaker stated if you are putting in an OBD1 engine into your OBD2 you will need to get the conversion harness, follow his links.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordMD »</TD></TR><TR><TD CLASS="quote">need to know where to get one in the frederick md area or online... any sugestion? also anyone know a good spot to do the install in frederick county md? i lack the tools to do it myself</TD></TR></TABLE>
if you want to have one made for you... contact hasport... they did mine for like 300 ... nicely done and you just have to pritty much plug **** in... i paid the money because im not the best with wiring and i had my hands full doing the swap stuff.... good luck...
