LS motor overheats, loud clicking noise from engine block.
Old Jul 10, 2005 | 12:44 PM
Kapolei INTEGRA's Avatar
Default LS motor overheats, loud clicking noise from engine block.
ever since i drove my car hard, the engine made a LOUD clicking noise...and overheats...to the point that my radiator hose grew in size and popped . the engine will increase the clicking noise as the rpms raise. if i drive the car around long enough the engine will overheat and result in engine shutdown. i've gone so far as to replace the whole entire LS head with a new one and its still doing the same thing. so that rules out the need for a valve adjustment and thermostat. the problem lies in the engine block. What im thinking is that perhaps it might be the oil pump, water pump or the rod bearings. before i would want to take this out to a mechanic as a last resort, which im not really inclined to. I would like to hear from anyone with knowledge on this matter so that i might be able to diagnose and fix the problem. thanks.
Old Jul 10, 2005 | 12:53 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: LS motor overheats, loud clicking noise from engine block. (KapoleiINTEGRA)
sounds like its the water pump. the oil pump or anything else that has to do with oil wouldnt cause the hose to burst. did you see the hose grow and then burst? my old dsm had a coolant hose blow, and i replaced the hose, and filled the radiator with coolant. BUT, i didnt burp the sustem long enough, so after it ran for a few minutes the main radiator hose collapsed lol. i dont know what the cause of the engine knocking could be; im just guessing it could be a bad rod bearing. do you rev it past 7k?
Old Jul 10, 2005 | 02:00 PM
DoctorGSR's Avatar
thats exactly how my engine sounded when i spun a rod bearing.
Old Jul 10, 2005 | 03:26 PM
projectTeG's Avatar
did you replace the head gasket when you did the head swap?
Old Jul 10, 2005 | 03:28 PM
Default Re: LS motor overheats, loud clicking noise from engine block. (benb18a)
yup after the engine overheated, i opened the hood to let it cool down...and to my dismay i saw wut looked like an overgrown wart on the radiator hose . but yea the hose bursted and out went the coolant. and no i didnt rev past 7k...i kept it at a safe 5-6k rpm constant. but yea i wouldn't rule out a bad rod either. however, when i rev it up it sounds pretty linear not like it struggles or anything. soo wut u guys think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">sounds like its the water pump. the oil pump or anything else that has to do with oil wouldnt cause the hose to burst. did you see the hose grow and then burst? my old dsm had a coolant hose blow, and i replaced the hose, and filled the radiator with coolant. BUT, i didnt burp the sustem long enough, so after it ran for a few minutes the main radiator hose collapsed lol. i dont know what the cause of the engine knocking could be; im just guessing it could be a bad rod bearing. do you rev it past 7k?</TD></TR></TABLE>
Old Jul 10, 2005 | 03:30 PM
Default Re: (projectTeG)
yup i replace all the gaskets...intake, exhaust and the block itself. but it wouldn't be the cause of the knocking thats for sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">did you replace the head gasket when you did the head swap?</TD></TR></TABLE>
Old Jul 10, 2005 | 08:17 PM
honda1982's Avatar
Rod Bearing!!! 99.9% sure. Happen on my Friend LS-Vtec. LS motor seem to sprung Rod bearing all the time unless you rebuilt w./ stronger stuff. ARP, etc..
Old Jul 12, 2005 | 05:20 AM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
Default Re: (honda1982)
the description of the sound would most likely be a spun bearing...not very healthy at all..overheating? i have no info on that..
blue_egsi
Jun 16, 2013 11:40 PM
kingmickez25
Jun 14, 2012 06:46 PM
dust_101
10
Jun 19, 2006 07:26 AM
jbj728
Jun 19, 2005 05:18 PM
bobbyh
Mar 30, 2002 12:39 AM
