passenger axle removal
Old Jul 10, 2005 | 08:53 AM
Boosthead's Avatar
Default passenger axle removal
When all else fails, how do I get my axle out?!?!
I am retying to remove my passenger side axle to replace it. I have tried prying, jiggling, yanking, nothing is working. I thought I could use a punc and knock it out from the drivers side but there is a metal rod across the middle of the hole which prevents me from doing this.
Is there any other method that I am missing??
Old Jul 10, 2005 | 10:05 AM
Yambor's Avatar
Default Re: passenger axle removal (Boosthead)
pry man, pry.
Take a 1ft- 2ft prybar in between the axle and the tranny and pry. should click right out..then slide the rest of the way. I dont know why it wont come out, but ive done axles in 10min at the shop.. Pry...
Old Jul 10, 2005 | 10:11 AM
KeithsDAteg's Avatar
You cant be a ***** about it. Put the pry bar between the end of the axle and the tranny or half shaft, then pry fast and hard.
Its hard to explain without showing you.
I guess what I am trying to say is- hold the bottom of your pry bar and yank it.
Need any more help pm me.
Old Jul 10, 2005 | 10:22 AM
IN VTEC's Avatar
I use a pry bar and smack the end of the pry bar with the palm of my hand or with the small 1lb sledgehammer I have.
Old Jul 10, 2005 | 10:23 AM
Boosthead's Avatar
Default Re: passenger axle removal (JH4DC4-2GSR)
I'm still working at it. I have tried brute force. The problem is that my 24" pry bar wont fit at the right angle between the axle/tranny because of the subframe (i think that's what it was in the way) so I am using the smaller pry bars. I've done about a dozen axles and this wont seem to come out by brute force or finesse. I'll keep at it. Thanks guys.
Old Jul 10, 2005 | 10:24 AM
Default Re: passenger axle removal (IN VTEC)
keep doing that! I promise it will work.
solareclipseauto's Avatar
use a good pry bar or flat head and keep prying
Old Jul 10, 2005 | 10:27 AM
Default Re: passenger axle removal (solareclipseauto)
Constant pressure will not work as well as sudden pressure. There is a ring on the end of the axle that has to snap into a grove. This sudden pressure will cause it to pop right out of that grove.
Old Jul 10, 2005 | 10:30 AM
Boosthead's Avatar
Default Re: passenger axle removal (KeithsDAteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">Constant pressure will not work as well as sudden pressure. There is a ring on the end of the axle that has to snap into a grove. This sudden pressure will cause it to pop right out of that grove.</TD></TR></TABLE>
I agree and this is the method that has worked best for me in the past
Old Jul 10, 2005 | 10:34 AM
Keep me updated I am curious as to how this turns out.
Old Jul 10, 2005 | 10:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Prying probably will not work, at least it never has to me. The method shown in the Helms is what I always do and it always works quite easily for me. What you need to do is take a big flathead screwdriver and wedge it in between the axle joint and the differential housing. Stick the screwdriver in between there, and then tap it in further. The wedge shape of the screwdriver will force the snap ring on the axle out of the groove in the differential, and you should be able to pull it out quite easily.
Old Jul 10, 2005 | 01:03 PM
Yambor's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Prying probably will not work, at least it never has to me. The method shown in the Helms is what I always do and it always works quite easily for me. What you need to do is take a big flathead screwdriver and wedge it in between the axle joint and the differential housing. Stick the screwdriver in between there, and then tap it in further. The wedge shape of the screwdriver will force the snap ring on the axle out of the groove in the differential, and you should be able to pull it out quite easily.</TD></TR></TABLE>
Huh? i never heard of that..
Ive done about 20 honda axles and prying always works.. I guess ill have to try this next time..
Old Jul 10, 2005 | 01:37 PM
Community Builder
Default Re: (JH4DC4-2GSR)
well all I know is that is how the Helms shows to do it. I've had to remove my axles probably 5-6 times at least and wedging the screwdriver always works easily, no need to break your back underneath the car trying to pry the thing out.
Now the driver side axle is another story. That is a total PITA to get off, as there is nothing to wedge or pry against or anything. The only way is to take a big screwdriver, place it on the side of the joint and smack it with a BFH. Unfortunately this is quite difficult if you're trying to work underneath the car on jackstands. It is pretty easy if the car is on a lift, though, where you can get a good swing at it.
Old Jul 10, 2005 | 01:41 PM
DeeCeeTwo's Avatar
since ur just gonna replace it, might as well have a buddy yank on it while u pry, guarantee it will come off.
Old Jul 12, 2005 | 12:57 PM
weadd's Avatar
Hey man if you need help with this give me a call or PM.
88aeFC3S
Dec 23, 2010 07:43 AM
rice a roni
21
Apr 21, 2006 04:45 PM
Boosthead
Jul 10, 2005 10:32 AM
FlyZlow
18
Jan 5, 2005 08:21 AM
Doogie Howser
Sep 5, 2002 06:44 PM
