Wiring diagram for 00 Si Cluster to 97 Civic
Old Jul 10, 2005 | 01:35 AM
blinkn09's Avatar
Default Wiring diagram for 00 Si Cluster to 97 Civic
Hey guys, i have a 99-00 civic si gauge cluster in my 97 civic and i can't get my speedometer to work...do i need to rewire? everything else works. sorry i spent like a whole day searching the archives . can anyone point me in the right direction? thanks
Old Jul 10, 2005 | 01:39 AM
kkim's Avatar
Default Re: Wiring diagram for 00 Si Cluster to 97 Civic (blinkn09)
AFAIK, it should be plug and play.
Old Jul 10, 2005 | 01:48 AM
Timmay's Avatar
Default Re: Wiring diagram for 00 Si Cluster to 97 Civic (kkim)
plug and play
check the plug on the VSS located on the tranny, could be a loose connection or bad vss
Old Jul 10, 2005 | 03:08 AM
dh's Avatar
dh
Default Re: Wiring diagram for 00 Si Cluster to 97 Civic (Timmay)
Yeah the SI cluster is plug and play in 96-00 civics, and as Timmay said, it's probably your VSS. Or maybe your clusters broken.
Old Jul 10, 2005 | 10:13 AM
blinkn09's Avatar
Default Re: Wiring diagram for 00 Si Cluster to 97 Civic (Master Shake)
alright i'll check it out...thanks guys
Old Jul 14, 2005 | 09:51 AM
MyEvo8GotRepo's Avatar
i got a 98 civic and the 99 cluster isnt' plug and play at least not on dx model i need a diagram to make my cooling gauge work
Old Jul 14, 2005 | 09:57 AM
JDM-EJ1's Avatar
Yes, should work right up. Maybe the cluster is damaged?
Old Jul 19, 2005 | 07:34 PM
EeeJayEight's Avatar
Default Re: Wiring diagram for 00 Si Cluster to 97 Civic (JDM-EJ1)
it is plug and play... you should not have to change anything... check your vss
Old Jul 19, 2005 | 08:14 PM
green-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">AFAIK, it should be plug and play.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">plug and play
check the plug on the VSS located on the tranny, could be a loose connection or bad vss</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEMYEF8 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the SI cluster is plug and play in 96-00 civics, and as Timmay said, it's probably your VSS. Or maybe your clusters broken.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">it is plug and play... you should not have to change anything... check your vss</TD></TR></TABLE>
Plug and play man. Check your VSS and for loose connections first.
91blackEF
Jan 13, 2009 06:47 AM
Fo-Do Fanatic
Nov 7, 2007 07:11 AM
Nocturnal
Aug 31, 2003 07:37 PM
Mark Murda
Aug 8, 2003 09:17 AM
