Tranny slip during boost?
Old Jul 9, 2005 | 10:43 PM
trooper0641's Avatar
Default Tranny slip during boost?
I would put it into 2nd or 3rd...floor it...the car moves...hits full boost...full power comes in...and then slip off the gear simuliar to a mishift. Any ideas?
Old Jul 9, 2005 | 11:24 PM
Jimmy's Avatar
Global Moderator
Default Re: Tranny slip during boost? (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">I would put it into 2nd or 3rd...floor it...the car moves...hits full boost...full power comes in...and then slip off the gear simuliar to a mishift. Any ideas?</TD></TR></TABLE>
Slipping clutch?
A stock civic clutch can't hold lots of amount of boost for a long period of time..
If you plan on the 200whp area i'd go with ACT HDSS..
Goodluck!
Old Jul 9, 2005 | 11:31 PM
Default Re: Tranny slip during boost? (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Slipping clutch?
Goodluck!</TD></TR></TABLE>
a slipping clutch would do that? i thought a slipping clutch would just have trouble grabbing the gears. my clutch has more life and pressure than the average stock clutch. im slipping OUT of the gears not into. :[
Old Jul 10, 2005 | 04:36 AM
JDM-EJ1's Avatar
Slipping clutch?
Makes sense to me, that with that much power the clutch just can't handle all of it and it starts to slip.
Old Jul 10, 2005 | 05:43 AM
photec2's Avatar
Default Re: Tranny slip during boost? (JDM-EJ1)
if you are in gear and your RPMs all of a sudden go up really quick and you dont go faster it is your clutch slipping.
Old Jul 10, 2005 | 05:59 AM
Default Re: Tranny slip during boost? (photec2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by photec2 &raquo;</TD></TR><TR><TD CLASS="quote">if you are in gear and your RPMs all of a sudden go up really quick and you dont go faster it is your clutch slipping.</TD></TR></TABLE>
hmm...so that's what they call it? clutch slipping? when my car is in gear but it pops out of it...thats the clutch slipping?
Old Jul 10, 2005 | 06:41 AM
chrisknight's Avatar
If your car slips/pops out of gear it could be:
1: Worn or improperly adjusted linkage
2: Transaxle loose on engine
3: input gear bearing retainer broken or loose
4: worn shifter fork
Old Jul 10, 2005 | 09:03 AM
Default Re: Tranny slip during boost? (chrisknight)
ttt any more ideas?
Old Jul 10, 2005 | 12:35 PM
HeikDiesel's Avatar
my integra would pop out of 5th when the fluid level was low. Might wanna check fluid level, but thats not good if it pops out of gear
Old Jul 10, 2005 | 03:55 PM
Default Re: Tranny slip during boost? (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">my integra would pop out of 5th when the fluid level was low. Might wanna check fluid level, but thats not good if it pops out of gear</TD></TR></TABLE>
i dont have any fluids, its a cable.
Old Jul 10, 2005 | 04:15 PM
HeikDiesel's Avatar
excuse me? Fluid in the transmission...not for the slave cylinder
Old Jul 11, 2005 | 10:36 AM
Fluid level was good, just changed it this morning. For some reason it smelled burned. Now it doesnt slip AS much but still it slips and slows the car down.
Old Jul 11, 2005 | 12:04 PM
Dwight Schrute's Avatar
bad synchros
Old Jul 11, 2005 | 12:13 PM
Luserkid's Avatar
Default Re: Tranny slip during boost? (drewthomas14)
Ok were talking about 2 completely different things here. And its not clear which is your problem.
Slipping Clutch/Bad clutch: Your clutch doesnt grab, which would result in longer timing to engage and also not go anywhere. To test, start driving to 5mph and go into 4th gear, if your car still goes the clutch is slipping, if you stall then your clutch is good.
Bad tranny: Grinds, pops out of gear. If your driving down the street and all of the sudden you pop out of gear, also when you shift or in gear youll hear grinding. Those are normal causes. Things that could help if grinding is transmission flush. But if popping out of gear requires new Synchros or new tranny (usually alot cheaper then a rebuild)
Now which one is more or less your problem?
ivt-t
May 26, 2008 05:56 PM
fongyz22
Honda Civic (2001 - 2005)
Nov 19, 2007 09:33 AM
wernhersey
Mar 5, 2007 11:12 AM
DD_JonnyLee
Aug 28, 2003 06:21 AM
92HB_HB
Apr 19, 2002 08:11 PM
