B18A1 Dyno graph, feedback wanted
Old Jul 9, 2005 | 09:45 PM
DA9 Integra's Avatar
Default B18A1 Dyno graph, feedback wanted
Hey I just wanted to post my dyno graph and leave it up for feedback.
Any comments on the a/f ratio? i had it hooked up to a wideband to get some more accurate readings.
Old Jul 9, 2005 | 10:23 PM
YiNYaNg's Avatar
Default Re: B18A1 Dyno graph, feedback wanted (DA9 Integra)
You need to join the Dark Side=Boost
Old Jul 9, 2005 | 10:38 PM
dcb16's Avatar
pretty average numbers for i/h/e
Old Jul 9, 2005 | 10:40 PM
dcb16's Avatar
a/f looks like oem tuning
Old Jul 9, 2005 | 11:08 PM
sheepey's Avatar
Default Re: B18A1 Dyno graph, feedback wanted (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">You need to join the Dark Side=Boost </TD></TR></TABLE>
Or u can talk to Hrbird. Hes crazy with NA LS setups..
Old Jul 9, 2005 | 11:31 PM
importdude2000's Avatar
i guess its good for 209k!and 91
on my 92 i made
136 std 124std
i/h/e
msd
i think std is 4% higher than sae
if iam wrong please let me know
so i know
Old Jul 11, 2005 | 06:10 AM
Default Re: (importdude2000)
Anyone have an explanation for the bump at 4-4500?
Old Jul 11, 2005 | 12:00 PM
onefstek's Avatar
there is no real explanation for the bump. Its just the way the set up works. It makes good torque at that rpm.
I bet if you changed the IM you would loose that hump.
Old Jul 11, 2005 | 03:52 PM
DonF's Avatar
Default Re: (onefstek)
The dip @ 4600 is because it goes rich.
Old Jul 11, 2005 | 04:56 PM
Default Re:
Can't change the intake manifold in STS class. I'm building a motor outside the car back to stock specs, with the 0.25mm overbore pistons, balanced bottom end, possibly underdrive pulleys, and an SAFC on top of what I currently have.
Old Jul 11, 2005 | 06:57 PM
hybrid_vtec's Avatar
Default Re: Re: (DA9 Integra)
Your numbers look a lil low but still pretty average. With 209K on the motor I would look toward rebuilding the motor before going turbo. If you want to go N/A, now wouldnt be a bad time either.
Old Jul 12, 2005 | 08:47 AM
Default Re: Re: (hybrid_vtec)
Read the post I made right above yours. I don't see a turbo in there...
Old Jul 12, 2005 | 02:11 PM
moyo_rican's Avatar
yup with those numbers you should be good for some mid to high 15's
Old Jul 12, 2005 | 02:54 PM
Default Re: Re: (JUMPTHELIGHT)
I don't drag race.
Old Jul 13, 2005 | 03:30 PM
compare to mine
Old Jul 13, 2005 | 03:57 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
YOU CANT COMPARE THOSE TWO DYNO SHEETS BECAUSE THE FIRST ONE IS ON "SAE" CORRECTION AND THE SECOND IS ON "STD"
Old Jul 13, 2005 | 03:58 PM
Combustion Contraption's Avatar
Nice shop motto on that last dyno graph though.
Old Jul 14, 2005 | 12:17 AM
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">YOU CANT COMPARE THOSE TWO DYNO SHEETS BECAUSE THE FIRST ONE IS ON "SAE" CORRECTION AND THE SECOND IS ON "STD"</TD></TR></TABLE>
dam dont u do alot of dynos?
its about 3. something percent more
Old Jul 14, 2005 | 09:39 AM
DYNO-PRO
that completely depends on atmospheric conditions and yes i do alot of dyno's just my .02 compare apples to apples
dirt_06
Honda S2000
24
Jun 11, 2006 12:54 AM
Haleiwa-Brando
May 10, 2006 02:26 PM
biggie2005
Feb 22, 2004 02:25 PM
B2FiNiTY
Jul 13, 2002 08:42 AM
