should i replave valve guides
Old Jul 9, 2005 | 08:57 PM
turbo95eg6's Avatar
Default should i replave valve guides
are valve guides meant to last long...? Im sure my seals are worn- car loses 1qt a week....while i get the seals replaced should i get the guides replaced also...?
Old Jul 9, 2005 | 09:02 PM
_Cyclone_'s Avatar
Default Re: should i replave valve guides (turbo95eg6)
Does it only smoke while it's cold? If you're losing a quart a week, it's probably rings... and I know you're going to tell me "I did a compression test and it was 170 across the board", it doesn't matter. When does it smoke? In my experience... cars that smoke really bad on cold starts and stop after they're warmed up have bad valve guide seals. Mazda's and Hyundai's are known for this problem. Honda's are known for rings going bad, unless you dropped a guide seal completly... then that's a different story.
Old Jul 9, 2005 | 09:13 PM
turbo95eg6's Avatar
Default Re: should i replave valve guides (_Cyclone_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Cyclone_ &raquo;</TD></TR><TR><TD CLASS="quote">Does it only smoke while it's cold? If you're losing a quart a week, it's probably rings... and I know you're going to tell me "I did a compression test and it was 170 across the board", it doesn't matter. When does it smoke? In my experience... cars that smoke really bad on cold starts and stop after they're warmed up have bad valve guide seals. Mazda's and Hyundai's are known for this problem. Honda's are known for rings going bad, unless you dropped a guide seal completly... then that's a different story.</TD></TR></TABLE>
oh no no-my rings are ****- my block is getting sleeved and new pistons are on order-leak down test showed over 20% on two of the cylinders
When i first got my fresh bottom end 2 years ago (pistons+rods) from the first day it leaked a 1qt of oil a week....yea for two years a qt of oil i bought a week
We used a head that as used but we ported polished and added a cam....but i dont remember checking if the valve seals were in good shape....so i was kinda thinking that was the cause...?
Old Jul 9, 2005 | 09:14 PM
turbo95eg6's Avatar
are valve seals wear visible to the eye...?
Old Jul 9, 2005 | 09:20 PM
_Cyclone_'s Avatar
Unless they're damaged, it'll be hard to tell by the eye alone. Machine shops have tools that can measure that kind of thing, but if it's apart you might as well replace them anyways. Better to do it now, then have to take it all apart again later.
Old Jul 9, 2005 | 11:05 PM
turbo95eg6's Avatar
so i should just get the guides replaced too...? that was kinda the question
Old Jul 10, 2005 | 07:22 AM
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Cyclone_ &raquo;</TD></TR><TR><TD CLASS="quote">Machine shops have tools that can measure that kind of thing, but if it's apart you might as well replace them anyways. Better to do it now, then have to take it all apart again later.</TD></TR></TABLE>
Yes, that was my answer.
jc2801
27
Aug 25, 2015 08:22 PM
Blopez1125
Sep 15, 2013 08:50 PM
builtITRm22x
10
Sep 22, 2008 08:09 PM
vxturbociv
Jul 23, 2006 06:27 PM
ALLMOTOR18
Dec 27, 2003 07:54 AM
