HELP!!! B18C... Idle drops
Just wondering if anyone can give me some advice on this idle problem. I have a 95 GSR, can't figure out why after I step on gas and let rpms drop the idle drops below 500rpms and almost stalls out. could it be a vaccum leak or electrical. any advice apprectiated. thanks
thats great.. checking on all those now. theres no CEL and it idles low during cold starts around 1k. anymore ideas be good helps. thanks everyone.
you know i am having the same problem. i suspect my alternator is the issue. its possible that its not holding the charge in idle. when you are having that issue, check to see if an extra load makes the problem worse, or gets better without it. ie radio, air conditioning, etc.
Nisif
Nov 26, 2011 07:22 PM
