motor will not start!!!
Old Jul 9, 2005 | 03:21 PM
JDMcrxb16a's Avatar
Default motor will not start!!!
M b16a obd0 motor will not start. At first I was not getting spark. I saw that the person before me did not use the right dizzy. So i bought the right b16a distributor and now i am getting spark but my motor will still not start. Does my rotor have to be pointin towards the number one spot? I need to check if i am getting fuel but how do i do that? I waws also told to check my main relay. Where and what is that? I just bought the car and I had it running for two days and now it has been sitting for a week which isnt long but still I want my car back on the streets! Any help or suggestions would be mch appreciated!
Old Jul 10, 2005 | 06:20 PM
zccr-xsi's Avatar
if u hear a click sound when u trun your key on the main reley is still good!is all your gorunds hooked up?what cel are your ecu throwing?can u hear your fuel pump whizzing when u trun the key on?check the fuses under the dash and in the engine comparment.
Old Jul 10, 2005 | 07:46 PM
NikoZai's Avatar
Default Re: (vteckillenzc)
english isn't your first language is it. =D but you're right on track vteckillenzc!
You have spark, great - now find out if you have fuel
Then find out if your distributor is firing at the correct time.
Does it backfire atall? (excess fuel igniting too late to be effective)
I'm assuming it's cranking over and your battery is fine.
When you turn the key to the on position, do you hear a humming coming from the center of the car? That's your fuel pump priming. If you don't hear that, you probably don't have any fuel pressure and that would be the cause.
Old Jul 12, 2005 | 08:27 AM
JDMcrxb16a's Avatar
Default Re: Crazy!!! (JDMcrxb16a)
The idiot who had the car before me wired the fan into the ignition so when I turn it ot the on position I could not really tell. Me and my buddies took the fuel rail apart to see if fuel was getting through the injectors. They were. So we had fuel and spark but still nothing. It had to be the timing so we messed with my distributor and still nothing. We didnt think about making the gears TDC since it would have been random. Well my timing was off alot, like 6 teeth. Crazy thing it the timing belt was tight, and the belt and gears still had all their teeth. Whatever, but thanks for everyones help!
Old Jul 13, 2005 | 08:28 AM
zccr-xsi's Avatar
Default Re: (NikoZai)
lmao actually it is but my keyboard is shitty after spilling soda on it!
Old Jul 13, 2005 | 08:33 AM
zccr-xsi's Avatar
dude it sounds like u have blowen fues somewhere.hum?i really couldnt tell u without hearing or seeing the prob.is your sensors all hooked up like knock sensor and ****?does the mototr want to turn over?again what cel are u getting?if it was off by that much u need to reline up your cams see if it fixes it?dontforget to reset your ecu after everylil thing u try!being off by 6 teeth that prob. keeping it from starting.make sure u dont have any open wires anywhere!u got volts meter if so just start testing ****.LOL TRY PUTTING GAS IN IT LOL,J/K
fastlimegreencivic
Mar 23, 2013 05:34 PM
meanshyguy
Sep 26, 2009 03:42 PM
JASIYAH6
May 28, 2009 10:10 AM
CRXherbie91
May 14, 2008 05:49 AM
mellowboy
Jan 28, 2003 02:08 PM
