Suspension & Brakes Theory, alignment, spring rates....
Alignment before or after traction bars ?
Old Jul 9, 2005 | 03:13 PM
Frankie92481's Avatar
Default Alignment before or after traction bars ?
I will be installing the Tokico HP hit and Lakewood Traction Bars.
My question is, would it be better to do a wheel alignment before or after the install of the traction bars?
Old Jul 10, 2005 | 11:47 PM
eMpAtHy's Avatar
Default Re: Alignment before or after traction bars ? (Frankie92481)
if u havnt gotten an alignement yet, just wait. when you change ride height, you change your toe angle, camber angle, and possibly caster and the other angle. when you move them around, things might change. just wait till ur done with ur suspension mods to get ur alignment.
Old Jul 12, 2005 | 10:57 AM
rmcdaniels's Avatar
I unbolt the bars for my alignment, then put them back on and adjust them after the alignment is done. Otherwise they will affect the alignment. My alignment tech and I tried it with them on and it does mess with the alignment if he has to adjust anything.
Old Jul 12, 2005 | 11:41 AM
snowman0520's Avatar
install all at the same time let the suspension break in for a couple hundred miles then get an aligment.
btw caster does not get changed by chaging suspension. caster on pretty much all civics is permanent unless u do some major modification
Old Jul 12, 2005 | 11:49 AM
rmcdaniels's Avatar
I met a guy who swapped his upper control arms to change the caster, but that caused some other issues.
Old Jul 12, 2005 | 12:21 PM
that is true. what i was thinking of is MacPherson style suspension where the coilover assembly is what determines ur camber and caster. if u increase caster ull have more neg camber on the outside wheel while conering. wish i knew what the specs were on civics.
Old Jul 26, 2005 | 06:32 AM
Default Re: Alignment before or after traction bars ? (eMpAtHy)
Thanks everyone for the help.
Blamm!!
Apr 7, 2008 04:34 AM
Siegfried
Jun 1, 2007 06:42 AM
Greyout
18
Aug 4, 2004 12:47 PM
TEG98
Apr 6, 2003 08:33 AM
Type R1
Apr 24, 2002 05:14 PM
